<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-low-or-completely-discharged-battery-338.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-service-campaign-onstar-system-inoperative-15.html</guid>
										<title>2009 Corvette: Service Campaign: OnStar System Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-service-campaign-onstar-system-inoperative-15.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-diagnostic-trouble-codes-220.html</guid>
										<title>2006 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-diagnostic-trouble-codes-220.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-2008-corvette-gm-techlink-article-auto-volume-error-103.html</guid>
										<title>2007 - 2008 Corvette: GM TechLink Article: Auto Volume Error</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-2008-corvette-gm-techlink-article-auto-volume-error-103.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-actual-outside-temperature-does-not-match-temperature-reading-on-inter-display-normal-operating-characteristic-341.html</guid>
										<title>2005 Corvette: Service Bulletin: Actual Outside Temperature Does Not Match Temperature Reading On Inter Display - Normal Operating Characteristic</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-actual-outside-temperature-does-not-match-temperature-reading-on-inter-display-normal-operating-characteristic-341.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-2013-corvette-service-bulletin-pic4510c-onstar®-tbt-turn-by-turn-and-digit-display-location-jul-18-2012-1337.html</guid>
										<title>2007 - 2013 Corvette: Service Bulletin: #PIC4510C: OnStar® TBT (Turn by Turn) And Digit Display Location - (Jul 18, 2012)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-2013-corvette-service-bulletin-pic4510c-onstar®-tbt-turn-by-turn-and-digit-display-location-jul-18-2012-1337.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-setting-the-clock-radio-337.html</guid>
										<title>2005 Corvette: GM TechLink: Setting the Clock Radio</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-setting-the-clock-radio-337.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2008-corvette-service-campaign-unwanted-repeat-calls-to-onstar-13.html</guid>
										<title>2004 - 2008 Corvette: Service Campaign: Unwanted Repeat Calls to OnStar</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2008-corvette-service-campaign-unwanted-repeat-calls-to-onstar-13.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-exterior-lamps-circuit-206.html</guid>
										<title>2006 Corvette: Electrical Schematic: Exterior Lamps Circuit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-exterior-lamps-circuit-206.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-gm-techlink-electronic-brake-control-module-communication-67.html</guid>
										<title>2009 - 2011 Corvette: GM TechLink:  Electronic Brake Control Module Communication</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-gm-techlink-electronic-brake-control-module-communication-67.html</link>
