<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-chevrolet-service-engineering-letter-service-procedures-for-clutch-gear-slinger-on-muncie-4-speed-passenger-transmissions-33.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-whistle-or-whine-in-reverse-or-lo-1-at-idle-thm-350c-mx3-984.html</guid>
										<title>1981 Corvette:  Service Bulletin:  Whistle or Whine in Reverse or Lo 1 at Idle - THM 350C (MX3)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-whistle-or-whine-in-reverse-or-lo-1-at-idle-thm-350c-mx3-984.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-output-shaft-speedo-gear-clip-holes-1114.html</guid>
										<title>1982 Corvette:  Service Bulletin:  Output Shaft Speedo Gear Clip Holes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-output-shaft-speedo-gear-clip-holes-1114.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-3-4-clutch-2-4-band-service-information-1111.html</guid>
										<title>1982 - 1991 Corvette:  Service Bulletin:  3-4 Clutch / 2-4 Band Service Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-3-4-clutch-2-4-band-service-information-1111.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-engineering-service-letter-speedometer-shaft-failure-24.html</guid>
										<title>1969 Corvette: Engineering Service Letter:  Speedometer Shaft Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-engineering-service-letter-speedometer-shaft-failure-24.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1971-corvette-service-news-front-servo-and-front-accumulator-piston-identification-turbo-hydra-matic-400-transmission-1023.html</guid>
										<title>1968 - 1971 Corvette:  Service News:  Front Servo and Front Accumulator Piston Identification - Turbo Hydra-Matic 400 Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1971-corvette-service-news-front-servo-and-front-accumulator-piston-identification-turbo-hydra-matic-400-transmission-1023.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-service-bulletin-propeller-shaft-assemblies-704.html</guid>
										<title>1980 Corvette: Service Bulletin: Propeller Shaft Assemblies</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-service-bulletin-propeller-shaft-assemblies-704.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-driveline-clicking-or-snapping-noise-173.html</guid>
										<title>1968 Corvette: Service Bulletin: Driveline Clicking or Snapping Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-driveline-clicking-or-snapping-noise-173.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-1974-1975-corvette-with-4-spd-transmission-684.html</guid>
										<title>1974 - 1975 Corvette: Service Bulletin: Stripped Speedometer Driven Gear, 1974-1975 Corvette with 4-Spd. Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-1974-1975-corvette-with-4-spd-transmission-684.html</link>
