<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-low-coolant-system-operation-328.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-engine-oil-life-monitor-reset-335.html</guid>
										<title>2005 - 2006 Corvette: Engine Oil Life Monitor Reset</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-engine-oil-life-monitor-reset-335.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-gm-techlink-article-dtc-p0300-setting-after-engine-repairs-6.html</guid>
										<title>2005 - 2013 Corvette: GM TechLink Article: DTC P0300 Setting after Engine Repairs</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-gm-techlink-article-dtc-p0300-setting-after-engine-repairs-6.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2005-corvette-gm-techlink-fuel-line-quick-connectors-387.html</guid>
										<title>2004 - 2005 Corvette: GM TechLink: Fuel Line Quick Connectors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2005-corvette-gm-techlink-fuel-line-quick-connectors-387.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-axle-vent-noise-329.html</guid>
										<title>2005 Corvette: GM TechLink: Axle Vent Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-axle-vent-noise-329.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-service-bulletin-excessive-oil-consumption-136.html</guid>
										<title>2009 Corvette: Service Bulletin:  Excessive Oil Consumption</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-service-bulletin-excessive-oil-consumption-136.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-2013-corvette-service-bulletin-pf48-pf48f-oil-filter-redesign-851.html</guid>
										<title>2008 - 2013 Corvette: Service Bulletin: PF48 / PF48F Oil Filter Redesign</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-2013-corvette-service-bulletin-pf48-pf48f-oil-filter-redesign-851.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-2008-corvette-gm-techlink-article-intake-airflow-disturbance-105.html</guid>
										<title>2007 - 2008 Corvette: GM TechLink Article: Intake Airflow Disturbance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-2008-corvette-gm-techlink-article-intake-airflow-disturbance-105.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-and-prior-corvettes-fuel-and-oil-additives-facts-and-myths-maximizing-fuel-economy-326.html</guid>
										<title>2006 and Prior Corvettes: Fuel and Oil Additives - Facts and Myths/Maximizing Fuel Economy</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-and-prior-corvettes-fuel-and-oil-additives-facts-and-myths-maximizing-fuel-economy-326.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-2013-corvette-service-bulletin-15682-primary-tank-module-flange-fuel-and-vapor-leaks-1293.html</guid>
										<title>2007 - 2013 Corvette: Service Bulletin: 15682 Primary Tank Module Flange Fuel and Vapor Leaks</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-2013-corvette-service-bulletin-15682-primary-tank-module-flange-fuel-and-vapor-leaks-1293.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-ls2-engine-trouble-codes-listing-332.html</guid>
										<title>2005 Corvette: LS2 Engine Trouble Codes Listing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-ls2-engine-trouble-codes-listing-332.html</link>
