										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-manual-transmission-operating-characteristics-195.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: Manual Transmission Operating Characteristics</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-manual-transmission-operating-characteristics-195.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-z06-dealer-bulletin-addition-of-optional-z06-chrome-wheel-313.html</guid>
										<title>2007 Corvette Z06: Dealer Bulletin: Addition Of Optional Z06 Chrome Wheel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-z06-dealer-bulletin-addition-of-optional-z06-chrome-wheel-313.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-techlink-car-wash-tire-fitment-320.html</guid>
										<title>2006 Corvette Z06: GM TechLink: Car Wash - Tire Fitment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-techlink-car-wash-tire-fitment-320.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-4l60-e-4l65-e-automatic-transmission-fluid-leak-from-oil-pump-or-bell-housing-area-276.html</guid>
										<title>2006 Corvette: Service Bulletin:  4L60-E, 4L65-E Automatic Transmission fluid Leak from Oil Pump or Bell Housing Area</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-4l60-e-4l65-e-automatic-transmission-fluid-leak-from-oil-pump-or-bell-housing-area-276.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2007-corvette-z06-service-bulletin-flushing-remote-oil-tank-when-replacing-engine-316.html</guid>
										<title>2006 - 2007 Corvette Z06: Service Bulletin: Flushing Remote Oil Tank When Replacing Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2007-corvette-z06-service-bulletin-flushing-remote-oil-tank-when-replacing-engine-316.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-collison-repair-and-complete-identification-manual-274.html</guid>
										<title>2006 Corvette Z06:  GM Collison Repair and Complete Identification Manual</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-collison-repair-and-complete-identification-manual-274.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-z06-and-zr1-gm-techlink-article-oil-system-changes-ls7-and-ls9-106.html</guid>
										<title>2009 Corvette Z06 and ZR1: GM TechLink Article: Oil System Changes - LS7 and LS9</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-z06-and-zr1-gm-techlink-article-oil-system-changes-ls7-and-ls9-106.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2009-corvette-service-bulletin-clutch-hydraulic-system-new-service-owner-maintenance-information-58.html</guid>
										<title>2005 - 2009 Corvette:  Service Bulletin: Clutch Hydraulic System -- New Service/Owner Maintenance Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2009-corvette-service-bulletin-clutch-hydraulic-system-new-service-owner-maintenance-information-58.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2012-corvette-z06-gm-techlink-drive-belt-noise-and-crankshaft-balancer-runout-71.html</guid>
										<title>2009 - 2012 Corvette Z06: GM TechLink: Drive Belt Noise and Crankshaft Balancer Runout</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2012-corvette-z06-gm-techlink-drive-belt-noise-and-crankshaft-balancer-runout-71.html</link>
