<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2007-corvette-z06-customer-satisfaction-campaign-06092-brake-pad-inspection-318.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2013-corvette-z06-technical-article-robotic-trimming-radically-shortens-corvette-fender-production-cycle-167.html</guid>
										<title>2006 - 2013 Corvette Z06: Technical Article: Robotic trimming radically shortens Corvette fender production cycle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2013-corvette-z06-technical-article-robotic-trimming-radically-shortens-corvette-fender-production-cycle-167.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-2005-2006-chevrolet-corvette-including-z06-repair-procedure-for-painted-roofs-that-may-separate-364.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: 2005-2006 Chevrolet Corvette Including Z06 Repair Procedure for Painted Roofs that may separate</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-2005-2006-chevrolet-corvette-including-z06-repair-procedure-for-painted-roofs-that-may-separate-364.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2009-corvette-z06-and-zr1-gm-techlink-excess-oil-in-air-intake-snorkel-109.html</guid>
										<title>2006 - 2009 Corvette Z06 and ZR1: GM TechLink: Excess Oil in Air Intake Snorkel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2009-corvette-z06-and-zr1-gm-techlink-excess-oil-in-air-intake-snorkel-109.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvettes-all-models-grand-sport-stripe-kit-part-numbers-1184.html</guid>
										<title>2005 - 2013 Corvettes - All Models:  Grand Sport Stripe Kit Part Numbers</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2009-corvette-z06-and-zr1-gm-techlink-article-oil-reservoir-rattle-112.html</guid>
										<title>2006 - 2009 Corvette Z06 and ZR1: GM TechLink Article: Oil Reservoir Rattle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2009-corvette-z06-and-zr1-gm-techlink-article-oil-reservoir-rattle-112.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-rear-axle-clunk-and-or-chatter-type-noise-on-turns-171.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin:  Rear Axle Clunk and/or Chatter Type Noise on Turns</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-rear-axle-clunk-and-or-chatter-type-noise-on-turns-171.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2013-corvette-z06-service-bulletin-information-on-customer-questions-about-valve-guide-wear-43.html</guid>
										<title>2006 - 2013 Corvette Z06: Service Bulletin: Information on Customer Questions About Valve Guide Wear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2013-corvette-z06-service-bulletin-information-on-customer-questions-about-valve-guide-wear-43.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-techlink-vehicle-identification-number-319.html</guid>
										<title>2006 Corvette Z06: GM TechLink: Vehicle Identification Number</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-techlink-vehicle-identification-number-319.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-recall-painted-roof-adhesive-separation-273.html</guid>
										<title>2005 - 2006 Corvette: Recall: Painted Roof Adhesive Separation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-recall-painted-roof-adhesive-separation-273.html</link>
