<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2007-corvette-z06-service-bulletin-flushing-remote-oil-tank-when-replacing-engine-316.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-z06-and-zr1-gm-techlink-article-oil-system-changes-ls7-and-ls9-106.html</guid>
										<title>2009 Corvette Z06 and ZR1: GM TechLink Article: Oil System Changes - LS7 and LS9</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-z06-and-zr1-gm-techlink-article-oil-system-changes-ls7-and-ls9-106.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2007-corvette-z06-customer-satisfaction-campaign-06092-brake-pad-inspection-318.html</guid>
										<title>2006 - 2007 Corvette Z06: Customer Satisfaction Campaign 06092: Brake Pad Inspection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2007-corvette-z06-customer-satisfaction-campaign-06092-brake-pad-inspection-318.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-spongy-clutch-pedal-sticking-to-the-floor-during-hard-acceleration-and-high-rpm-shifts-186.html</guid>
										<title>2005 - 2007 Corvette:  Service Bulletin:  Intermittent Spongy Clutch Pedal Sticking To The Floor During Hard Acceleration And High RPM Shifts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-spongy-clutch-pedal-sticking-to-the-floor-during-hard-acceleration-and-high-rpm-shifts-186.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-2005-2006-chevrolet-corvette-including-z06-repair-procedure-for-painted-roofs-that-may-separate-364.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: 2005-2006 Chevrolet Corvette Including Z06 Repair Procedure for Painted Roofs that may separate</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-2005-2006-chevrolet-corvette-including-z06-repair-procedure-for-painted-roofs-that-may-separate-364.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-customer-satisfaction-program-engine-flywheel-clutch-interference-327.html</guid>
										<title>2006 Corvette: Customer Satisfaction Program: Engine Flywheel/Clutch Interference</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2009-corvette-z06-and-zr1-gm-techlink-article-oil-reservoir-rattle-112.html</guid>
										<title>2006 - 2009 Corvette Z06 and ZR1: GM TechLink Article: Oil Reservoir Rattle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2009-corvette-z06-and-zr1-gm-techlink-article-oil-reservoir-rattle-112.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2013-corvette-z06-technical-article-robotic-trimming-radically-shortens-corvette-fender-production-cycle-167.html</guid>
										<title>2006 - 2013 Corvette Z06: Technical Article: Robotic trimming radically shortens Corvette fender production cycle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2013-corvette-z06-technical-article-robotic-trimming-radically-shortens-corvette-fender-production-cycle-167.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-dry-sump-oiling-system-315.html</guid>
										<title>2006 Corvette Z06: Dry Sump Oiling System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-dry-sump-oiling-system-315.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2013-corvette-z06-service-bulletin-information-on-customer-questions-about-valve-guide-wear-43.html</guid>
										<title>2006 - 2013 Corvette Z06: Service Bulletin: Information on Customer Questions About Valve Guide Wear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2013-corvette-z06-service-bulletin-information-on-customer-questions-about-valve-guide-wear-43.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-techlink-vehicle-identification-number-319.html</guid>
										<title>2006 Corvette Z06: GM TechLink: Vehicle Identification Number</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-techlink-vehicle-identification-number-319.html</link>
