<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-service-bulletin-information-on-over-filling-dry-sump-oiling-system-and-maintaining-proper-oil-level-on-ls7-engine-314.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-customer-satisfaction-program-engine-flywheel-clutch-interference-327.html</guid>
										<title>2006 Corvette: Customer Satisfaction Program: Engine Flywheel/Clutch Interference</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2007-corvette-z06-customer-satisfaction-campaign-06092-brake-pad-inspection-318.html</guid>
										<title>2006 - 2007 Corvette Z06: Customer Satisfaction Campaign 06092: Brake Pad Inspection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2007-corvette-z06-customer-satisfaction-campaign-06092-brake-pad-inspection-318.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-collison-repair-and-complete-identification-manual-274.html</guid>
										<title>2006 Corvette Z06:  GM Collison Repair and Complete Identification Manual</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-collison-repair-and-complete-identification-manual-274.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2007-corvette-z06-service-bulletin-flushing-remote-oil-tank-when-replacing-engine-316.html</guid>
										<title>2006 - 2007 Corvette Z06: Service Bulletin: Flushing Remote Oil Tank When Replacing Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2007-corvette-z06-service-bulletin-flushing-remote-oil-tank-when-replacing-engine-316.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-techlink-vehicle-identification-number-319.html</guid>
										<title>2006 Corvette Z06: GM TechLink: Vehicle Identification Number</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-techlink-vehicle-identification-number-319.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-dry-sump-oiling-system-315.html</guid>
										<title>2006 Corvette Z06: Dry Sump Oiling System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-dry-sump-oiling-system-315.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-z06-gm-techlink-article-clutch-pedal-doesn-t-return-102.html</guid>
										<title>2008 Corvette Z06: GM TechLink Article: Clutch Pedal Doesn`t Return</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-z06-gm-techlink-article-clutch-pedal-doesn-t-return-102.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2013-corvette-z06-service-bulletin-information-on-customer-questions-about-valve-guide-wear-43.html</guid>
										<title>2006 - 2013 Corvette Z06: Service Bulletin: Information on Customer Questions About Valve Guide Wear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2013-corvette-z06-service-bulletin-information-on-customer-questions-about-valve-guide-wear-43.html</link>
