										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2001-corvette-convertible-service-bulletin-squeak-from-rear-of-convertible-top-replace-protector-assembly-459.html</guid>
										<title>1998 - 2001 Corvette Convertible: Service Bulletin: Squeak From Rear of Convertible Top (Replace Protector Assembly)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2001-corvette-convertible-service-bulletin-squeak-from-rear-of-convertible-top-replace-protector-assembly-459.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2000-corvette-service-bulletin-window-motor-noisy-inoperative-461.html</guid>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2000-corvette-service-bulletin-window-motor-noisy-inoperative-461.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2002-corvette-service-bulletin-higher-than-expected-oil-consumption-308.html</guid>
										<title>1999 - 2002 Corvette: Service Bulletin: Higher Than Expected Oil Consumption</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-trunk-door-on-convertible-won-t-open-all-the-way-457.html</guid>
										<title>1998 - 2003 Corvette Convertible: Trunk Door on Convertible Won`t Open All The Way</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-trunk-door-on-convertible-won-t-open-all-the-way-457.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-general-waterleak-guide-466.html</guid>
										<title>1997 - 2004 Corvette: Service Bulletin: General Waterleak Guide</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-general-waterleak-guide-466.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2003-corvette-service-bulletin-engine-knock-or-lifter-noise-393.html</guid>
										<title>2001 - 2003 Corvette: Service Bulletin: Engine Knock or Lifter Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2003-corvette-service-bulletin-engine-knock-or-lifter-noise-393.html</link>
