<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-1978-corvette-service-bulletin-rear-bumper-cover-wavy-31.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1977-corvette-service-bulletin-thawing-frozen-door-locks-and-preventing-future-freezing-1083.html</guid>
										<title>1976 - 1977 Corvette:  Service Bulletin:  Thawing Frozen Door Locks and Preventing Future Freezing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1977-corvette-service-bulletin-thawing-frozen-door-locks-and-preventing-future-freezing-1083.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-headlamp-opening-interference-696.html</guid>
										<title>1969 Corvette: Service Bulletin: Headlamp Opening Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-headlamp-opening-interference-696.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-cracking-of-the-plenum-at-the-right-hood-latch-plate-944.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Cracking of the Plenum at the Right Hood Latch Plate</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-cracking-of-the-plenum-at-the-right-hood-latch-plate-944.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-removable-roof-panel-fit-972.html</guid>
										<title>1978 Corvette:  Service Bulletin:  Removable Roof Panel Fit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-removable-roof-panel-fit-972.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-lubrication-of-window-regulator-shaft-719.html</guid>
										<title>1968 Corvette: Service Bulletin: Lubrication of Window Regulator Shaft</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-lubrication-of-window-regulator-shaft-719.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-1973-corvette-service-bulletin-engine-overheat-1220.html</guid>
										<title>1970 - 1973 Corvette:  Service Bulletin:  Engine Overheat</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-1973-corvette-service-bulletin-engine-overheat-1220.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-recall-product-campaign-no-8005-left-front-fender-skirt-to-brake-pipe-clearance-867.html</guid>
										<title>1968 Corvette: Recall: Product Campaign No. 8005 Left Front Fender Skirt to Brake Pipe Clearance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-recall-product-campaign-no-8005-left-front-fender-skirt-to-brake-pipe-clearance-867.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-chevrolet-engineering-memo-window-service-update-1227.html</guid>
										<title>1968 Corvette:  Chevrolet Engineering Memo:  Window Service Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-chevrolet-engineering-memo-window-service-update-1227.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-news-lock-set-deviation-713.html</guid>
										<title>1978 Corvette: Service News: Lock Set Deviation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-news-lock-set-deviation-713.html</link>
