										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-whistle-noise-from-intake-manifold-throttle-body-replace-intake-manifold-390.html</guid>
										<title>2001 Corvette: Service Bulletin: Whistle Noise From Intake Manifold/Throttle Body (Replace Intake Manifold)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-whistle-noise-from-intake-manifold-throttle-body-replace-intake-manifold-390.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-audible-spark-knock-detonation-mil-illuminated-dtc-p0332-set-396.html</guid>
										<title>1998 - 2002 Corvette: Service Bulletin: Audible Spark Knock (Detonation), MIL Illuminated, DTC P0332 Set</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-audible-spark-knock-detonation-mil-illuminated-dtc-p0332-set-396.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-service-bulletin-intermittent-accessory-drive-rumble-during-garage-shift-399.html</guid>
										<title>1997 - 2000 Corvette: Service Bulletin: Intermittent Accessory Drive Rumble During Garage Shift</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-service-bulletin-intermittent-accessory-drive-rumble-during-garage-shift-399.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2005-corvette-gm-techlink-fuel-line-quick-connectors-387.html</guid>
										<title>2004 - 2005 Corvette: GM TechLink: Fuel Line Quick Connectors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2005-corvette-gm-techlink-fuel-line-quick-connectors-387.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-2004-corvette-gm-techlink-coolant-leak-at-cup-plugs-388.html</guid>
										<title>2003 - 2004 Corvette: GM TechLink: Coolant Leak at Cup Plugs</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-2004-corvette-gm-techlink-coolant-leak-at-cup-plugs-388.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-accessory-drive-squeak-replace-idler-pulley-401.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: Accessory Drive Squeak (Replace Idler Pulley)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-accessory-drive-squeak-replace-idler-pulley-401.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/procedure-for-replacing-the-reveal-moldings-over-side-windows-on-a-2001-2004-corvette-z06-1409.html</guid>
										<title>Procedure for Replacing the Reveal Moldings Over Side Windows on a 2001 - 2004 Corvette Z06</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/procedure-for-replacing-the-reveal-moldings-over-side-windows-on-a-2001-2004-corvette-z06-1409.html</link>
