<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-evaluation-3m-scotchcal-car-bra-300.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-delco-freedom-battery-diagnosis-information-292.html</guid>
										<title>Service Bulletin: Delco Freedom Battery Diagnosis Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-delco-freedom-battery-diagnosis-information-292.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/determining-the-resistance-value-of-the-ignition-key-resistor-pellet-291.html</guid>
										<title>Determining the Resistance Value of the Ignition Key Resistor Pellet</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/determining-the-resistance-value-of-the-ignition-key-resistor-pellet-291.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-review-best-all-round-we-test-the-goodyear-f1-gs-d3-279.html</guid>
										<title>Product Review:  Best All-Round:  We Test the Goodyear F1 GS-D3</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-review-best-all-round-we-test-the-goodyear-f1-gs-d3-279.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/chevrolet-service-bulletin-information-on-proper-tire-pressure-202.html</guid>
										<title>Chevrolet Service Bulletin: Information on Proper Tire Pressure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/chevrolet-service-bulletin-information-on-proper-tire-pressure-202.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-cleaning-coating-and-painting-of-aluminum-wheels-278.html</guid>
										<title>Service Bulletin: Cleaning, Coating and Painting of Aluminum Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-cleaning-coating-and-painting-of-aluminum-wheels-278.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-timing-and-vacuum-advance-101-253.html</guid>
										<title>Technical Article:  Timing and Vacuum Advance 101</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-timing-and-vacuum-advance-101-253.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-set-up-a-bg-speed-demon-basic-89.html</guid>
										<title>Technical Article: How to Set Up a BG Speed Demon (basic)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-set-up-a-bg-speed-demon-basic-89.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-advantages-of-an-oil-prime-tool-251.html</guid>
										<title>Technical Article:  Advantages of an Oil Prime Tool</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-advantages-of-an-oil-prime-tool-251.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/gm-press-release-april-22-1996-zora-arkus-duntov-833.html</guid>
										<title>GM Press Release:  April 22, 1996: Zora Arkus-Duntov</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-riveting-experience-home-restorer-s-guide-to-installing-soft-aluminum-rivets-on-your-corvette-245.html</guid>
										<title>Technical Article:  Riveting Experience - Home-Restorer`s Guide to Installing Soft Aluminum Rivets on your Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-riveting-experience-home-restorer-s-guide-to-installing-soft-aluminum-rivets-on-your-corvette-245.html</link>
