<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1967-corvette-chevrolet-service-news-dual-main-cylinder-component-replacement-30.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1982-corvette-recall-remanufactured-brake-calipers-750.html</guid>
										<title>1965 - 1982 Corvette: Recall: Remanufactured Brake Calipers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1982-corvette-recall-remanufactured-brake-calipers-750.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-news-corvette-heavy-duty-brakes-introduction-966.html</guid>
										<title>1966 Corvette:  Service News:  Corvette Heavy Duty Brakes - Introduction</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-news-corvette-heavy-duty-brakes-introduction-966.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-news-dual-main-cylinder-component-replacement-875.html</guid>
										<title>1967 Corvette: Service News: Dual Main Cylinder Component Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-news-dual-main-cylinder-component-replacement-875.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-engineering-service-letter-disc-brake-shoe-organic-lining-wear-1005.html</guid>
										<title>1967 Corvette:  Engineering Service Letter:  Disc Brake Shoe Organic Lining Wear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-engineering-service-letter-disc-brake-shoe-organic-lining-wear-1005.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-field-service-engineering-riveted-brake-pads-1132.html</guid>
										<title>1966 Corvette:  Field Service Engineering:  Riveted Brake Pads</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-field-service-engineering-riveted-brake-pads-1132.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-servicing-corvette-disc-brakes-79.html</guid>
										<title>1965 Corvette:  Service News:  Servicing Corvette Disc Brakes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-servicing-corvette-disc-brakes-79.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-parking-brake-cable-clip-retention-866.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Parking Brake Cable Clip Retention</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-parking-brake-cable-clip-retention-866.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-interim-production-changes-1024.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Interim Production Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-interim-production-changes-1024.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-disc-brake-squeal-977.html</guid>
										<title>1965 Corvette:  Service Bulletin:  Disc Brake Squeal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-disc-brake-squeal-977.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1972-corvette-service-news-corvette-parking-brake-shoe-removal-and-installation-procedure-revised-751.html</guid>
										<title>1963 - 1972 Corvette: Service News: Corvette Parking Brake Shoe Removal and Installation Procedure Revised</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1972-corvette-service-news-corvette-parking-brake-shoe-removal-and-installation-procedure-revised-751.html</link>
