<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-long-term-winter-corvette-storage-299.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/head-casting-numbers-chevrolet-small-block-engines-286.html</guid>
										<title>Head Casting Numbers: Chevrolet Small Block Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/head-casting-numbers-chevrolet-small-block-engines-286.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/error-codes-on-gm-radios-explained-290.html</guid>
										<title>Error Codes On GM Radios Explained</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/error-codes-on-gm-radios-explained-290.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-corvette-new-application-test-car-of-the-future-by-dave-mclellan-corvette-chief-engineer-1082.html</guid>
										<title>Technical Article:  Corvette - New Application Test Car of the Future - by Dave McLellan - Corvette Chief Engineer</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-corvette-new-application-test-car-of-the-future-by-dave-mclellan-corvette-chief-engineer-1082.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-delco-freedom-battery-diagnosis-information-292.html</guid>
										<title>Service Bulletin: Delco Freedom Battery Diagnosis Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-delco-freedom-battery-diagnosis-information-292.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/all-corvettes-service-bulletin-removal-of-tight-wheels-1189.html</guid>
										<title>All Corvettes:  Service Bulletin:  Removal of Tight Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/all-corvettes-service-bulletin-removal-of-tight-wheels-1189.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-removal-of-tight-wheels-277.html</guid>
										<title>Service Bulletin: Removal of Tight Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-removal-of-tight-wheels-277.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/press-release-batteries-101-how-lead-acid-batteries-work-289.html</guid>
										<title>Press Release: Batteries 101--How Lead-Acid Batteries Work</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/press-release-batteries-101-how-lead-acid-batteries-work-289.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/tire-storage-recommendations-298.html</guid>
										<title>Tire Storage Recommendations</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/tire-storage-recommendations-298.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/corvette-demographics-2009-142.html</guid>
										<title>Corvette Demographics - 2009</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/corvette-demographics-2009-142.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-advantages-of-an-oil-prime-tool-251.html</guid>
										<title>Technical Article:  Advantages of an Oil Prime Tool</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-advantages-of-an-oil-prime-tool-251.html</link>
