<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-minor-paint-repair-without-repainting-295.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-review-best-all-round-we-test-the-goodyear-f1-gs-d3-279.html</guid>
										<title>Product Review:  Best All-Round:  We Test the Goodyear F1 GS-D3</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-review-best-all-round-we-test-the-goodyear-f1-gs-d3-279.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/small-block-chevrolet-engine-crankshaft-specifications-284.html</guid>
										<title>Small Block Chevrolet Engine Crankshaft Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/small-block-chevrolet-engine-crankshaft-specifications-284.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-install-a-bg-speed-demon-basic-87.html</guid>
										<title>Technical Article: How to Install a BG Speed Demon (Basic)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-install-a-bg-speed-demon-basic-87.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/press-release-batteries-101-how-lead-acid-batteries-work-289.html</guid>
										<title>Press Release: Batteries 101--How Lead-Acid Batteries Work</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/press-release-batteries-101-how-lead-acid-batteries-work-289.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/small-block-and-big-block-engine-bore-and-stroke-chart-283.html</guid>
										<title>Small Block and Big Block Engine Bore and Stroke Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/small-block-and-big-block-engine-bore-and-stroke-chart-283.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-mapping-your-advance-curve-252.html</guid>
										<title>Technical Article:  Mapping Your Advance Curve</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-mapping-your-advance-curve-252.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-fluid-leak-detection-294.html</guid>
										<title>Service Bulletin: Fluid Leak Detection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-fluid-leak-detection-294.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/gm-press-release-april-22-1996-zora-arkus-duntov-833.html</guid>
										<title>GM Press Release:  April 22, 1996: Zora Arkus-Duntov</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/corvette-demographics-2009-142.html</guid>
										<title>Corvette Demographics - 2009</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/corvette-demographics-2009-142.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-leak-less-swapping-the-centerhead-in-your-corvette-and-keeping-leaks-at-bay-238.html</guid>
										<title>Technical Article: Leak Less - Swapping the Centerhead in Your Corvette and Keeping Leaks at Bay</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-leak-less-swapping-the-centerhead-in-your-corvette-and-keeping-leaks-at-bay-238.html</link>
