<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/error-codes-on-gm-radios-explained-290.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-leak-less-swapping-the-centerhead-in-your-corvette-and-keeping-leaks-at-bay-238.html</guid>
										<title>Technical Article: Leak Less - Swapping the Centerhead in Your Corvette and Keeping Leaks at Bay</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-leak-less-swapping-the-centerhead-in-your-corvette-and-keeping-leaks-at-bay-238.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-air-conditioning-system-maintenance-and-repair-297.html</guid>
										<title>Technical Article: Air Conditioning System Maintenance and Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-air-conditioning-system-maintenance-and-repair-297.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-riveting-experience-home-restorer-s-guide-to-installing-soft-aluminum-rivets-on-your-corvette-245.html</guid>
										<title>Technical Article:  Riveting Experience - Home-Restorer`s Guide to Installing Soft Aluminum Rivets on your Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-riveting-experience-home-restorer-s-guide-to-installing-soft-aluminum-rivets-on-your-corvette-245.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-evaluation-k-n-air-filter-vs-the-green-filter-285.html</guid>
										<title>Product Evaluation: K&N Air Filter vs. The Green Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-evaluation-k-n-air-filter-vs-the-green-filter-285.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/gm-press-release-april-22-1996-zora-arkus-duntov-833.html</guid>
										<title>GM Press Release:  April 22, 1996: Zora Arkus-Duntov</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-horsepower-vs-torque-280.html</guid>
										<title>Technical Article:  Horsepower vs. Torque</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-horsepower-vs-torque-280.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/engine-casting-numbers-chevrolet-v8-passenger-cars-287.html</guid>
										<title>Engine Casting Numbers: Chevrolet V8 Passenger Cars</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/engine-casting-numbers-chevrolet-v8-passenger-cars-287.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/small-block-and-big-block-engine-bore-and-stroke-chart-283.html</guid>
										<title>Small Block and Big Block Engine Bore and Stroke Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/small-block-and-big-block-engine-bore-and-stroke-chart-283.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-timing-and-vacuum-advance-101-253.html</guid>
										<title>Technical Article:  Timing and Vacuum Advance 101</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-timing-and-vacuum-advance-101-253.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-corvette-performance-testing-281.html</guid>
										<title>Technical Article:  Corvette Performance Testing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-corvette-performance-testing-281.html</link>
