<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/engine-casting-numbers-chevrolet-v8-passenger-cars-287.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-spring-thing-putting-the-spring-back-in-your-corvette-s-step-254.html</guid>
										<title>Technical Article: Spring Thing - Putting the &quot;Spring&quot; Back In Your Corvette`s Step</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-spring-thing-putting-the-spring-back-in-your-corvette-s-step-254.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-install-a-bg-speed-demon-basic-87.html</guid>
										<title>Technical Article: How to Install a BG Speed Demon (Basic)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-install-a-bg-speed-demon-basic-87.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-horsepower-vs-torque-280.html</guid>
										<title>Technical Article:  Horsepower vs. Torque</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-horsepower-vs-torque-280.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-long-term-winter-corvette-storage-299.html</guid>
										<title>Technical Article: Long Term / Winter Corvette Storage</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-long-term-winter-corvette-storage-299.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-riveting-experience-home-restorer-s-guide-to-installing-soft-aluminum-rivets-on-your-corvette-245.html</guid>
										<title>Technical Article:  Riveting Experience - Home-Restorer`s Guide to Installing Soft Aluminum Rivets on your Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-riveting-experience-home-restorer-s-guide-to-installing-soft-aluminum-rivets-on-your-corvette-245.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/gm-press-release-april-22-1996-zora-arkus-duntov-833.html</guid>
										<title>GM Press Release:  April 22, 1996: Zora Arkus-Duntov</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-problems-i-have-seen-with-commercially-rebuilt-q-jets-88.html</guid>
										<title>Technical Article: Problems I have Seen with Commercially Rebuilt Q-Jets</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-problems-i-have-seen-with-commercially-rebuilt-q-jets-88.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/buying-buying-a-corvette-and-what-to-look-for-293.html</guid>
										<title>Buying: Buying a Corvette and What to Look For</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/buying-buying-a-corvette-and-what-to-look-for-293.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-delco-freedom-battery-diagnosis-information-292.html</guid>
										<title>Service Bulletin: Delco Freedom Battery Diagnosis Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-delco-freedom-battery-diagnosis-information-292.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/small-block-and-big-block-engine-bore-and-stroke-chart-283.html</guid>
										<title>Small Block and Big Block Engine Bore and Stroke Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/small-block-and-big-block-engine-bore-and-stroke-chart-283.html</link>
