<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/head-casting-numbers-chevrolet-small-block-engines-286.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-synthetic-oil-use-282.html</guid>
										<title>Technical Article:  Synthetic Oil Use</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-synthetic-oil-use-282.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/gm-press-release-april-22-1996-zora-arkus-duntov-833.html</guid>
										<title>GM Press Release:  April 22, 1996: Zora Arkus-Duntov</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/small-block-and-big-block-engine-bore-and-stroke-chart-283.html</guid>
										<title>Small Block and Big Block Engine Bore and Stroke Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/small-block-and-big-block-engine-bore-and-stroke-chart-283.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/corvette-demographics-2009-142.html</guid>
										<title>Corvette Demographics - 2009</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/corvette-demographics-2009-142.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-advantages-of-an-oil-prime-tool-251.html</guid>
										<title>Technical Article:  Advantages of an Oil Prime Tool</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-advantages-of-an-oil-prime-tool-251.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-fluid-leak-detection-294.html</guid>
										<title>Service Bulletin: Fluid Leak Detection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-fluid-leak-detection-294.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-spring-thing-putting-the-spring-back-in-your-corvette-s-step-254.html</guid>
										<title>Technical Article: Spring Thing - Putting the &quot;Spring&quot; Back In Your Corvette`s Step</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-spring-thing-putting-the-spring-back-in-your-corvette-s-step-254.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-minor-paint-repair-without-repainting-295.html</guid>
										<title>Service Bulletin: Minor Paint Repair Without Repainting</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-minor-paint-repair-without-repainting-295.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-evaluation-3m-scotchcal-car-bra-300.html</guid>
										<title>Product Evaluation: 3M Scotchcal Car Bra</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-evaluation-3m-scotchcal-car-bra-300.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/buying-buying-a-corvette-and-what-to-look-for-293.html</guid>
										<title>Buying: Buying a Corvette and What to Look For</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/buying-buying-a-corvette-and-what-to-look-for-293.html</link>
