<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/small-block-and-big-block-engine-bore-and-stroke-chart-283.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/engine-casting-numbers-chevrolet-v8-passenger-cars-287.html</guid>
										<title>Engine Casting Numbers: Chevrolet V8 Passenger Cars</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/engine-casting-numbers-chevrolet-v8-passenger-cars-287.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-mapping-your-advance-curve-252.html</guid>
										<title>Technical Article:  Mapping Your Advance Curve</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-mapping-your-advance-curve-252.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-long-term-winter-corvette-storage-299.html</guid>
										<title>Technical Article: Long Term / Winter Corvette Storage</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-long-term-winter-corvette-storage-299.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-problems-i-have-seen-with-commercially-rebuilt-q-jets-88.html</guid>
										<title>Technical Article: Problems I have Seen with Commercially Rebuilt Q-Jets</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-problems-i-have-seen-with-commercially-rebuilt-q-jets-88.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-removal-of-tight-wheels-277.html</guid>
										<title>Service Bulletin: Removal of Tight Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-removal-of-tight-wheels-277.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/error-codes-on-gm-radios-explained-290.html</guid>
										<title>Error Codes On GM Radios Explained</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/error-codes-on-gm-radios-explained-290.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-repair-rebuild-your-alternator-90.html</guid>
										<title>Technical Article: How to Repair &amp; Rebuild your Alternator</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-repair-rebuild-your-alternator-90.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-fluid-leak-detection-294.html</guid>
										<title>Service Bulletin: Fluid Leak Detection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-fluid-leak-detection-294.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/gm-press-release-april-22-1996-zora-arkus-duntov-833.html</guid>
										<title>GM Press Release:  April 22, 1996: Zora Arkus-Duntov</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-advantages-of-an-oil-prime-tool-251.html</guid>
										<title>Technical Article:  Advantages of an Oil Prime Tool</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-advantages-of-an-oil-prime-tool-251.html</link>
