<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-horsepower-vs-torque-280.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/buying-buying-a-corvette-and-what-to-look-for-293.html</guid>
										<title>Buying: Buying a Corvette and What to Look For</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/buying-buying-a-corvette-and-what-to-look-for-293.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/press-release-batteries-101-how-lead-acid-batteries-work-289.html</guid>
										<title>Press Release: Batteries 101--How Lead-Acid Batteries Work</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/press-release-batteries-101-how-lead-acid-batteries-work-289.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-review-best-all-round-we-test-the-goodyear-f1-gs-d3-279.html</guid>
										<title>Product Review:  Best All-Round:  We Test the Goodyear F1 GS-D3</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-review-best-all-round-we-test-the-goodyear-f1-gs-d3-279.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/gm-press-release-april-22-1996-zora-arkus-duntov-833.html</guid>
										<title>GM Press Release:  April 22, 1996: Zora Arkus-Duntov</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-spring-thing-putting-the-spring-back-in-your-corvette-s-step-254.html</guid>
										<title>Technical Article: Spring Thing - Putting the &quot;Spring&quot; Back In Your Corvette`s Step</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-spring-thing-putting-the-spring-back-in-your-corvette-s-step-254.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-problems-i-have-seen-with-commercially-rebuilt-q-jets-88.html</guid>
										<title>Technical Article: Problems I have Seen with Commercially Rebuilt Q-Jets</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-problems-i-have-seen-with-commercially-rebuilt-q-jets-88.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-leak-less-swapping-the-centerhead-in-your-corvette-and-keeping-leaks-at-bay-238.html</guid>
										<title>Technical Article: Leak Less - Swapping the Centerhead in Your Corvette and Keeping Leaks at Bay</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-leak-less-swapping-the-centerhead-in-your-corvette-and-keeping-leaks-at-bay-238.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/determining-the-resistance-value-of-the-ignition-key-resistor-pellet-291.html</guid>
										<title>Determining the Resistance Value of the Ignition Key Resistor Pellet</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/determining-the-resistance-value-of-the-ignition-key-resistor-pellet-291.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-timing-and-vacuum-advance-101-253.html</guid>
										<title>Technical Article:  Timing and Vacuum Advance 101</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-timing-and-vacuum-advance-101-253.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-evaluation-k-n-air-filter-vs-the-green-filter-285.html</guid>
										<title>Product Evaluation: K&N Air Filter vs. The Green Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-evaluation-k-n-air-filter-vs-the-green-filter-285.html</link>
