<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-cleaning-coating-and-painting-of-aluminum-wheels-278.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/small-block-and-big-block-engine-bore-and-stroke-chart-283.html</guid>
										<title>Small Block and Big Block Engine Bore and Stroke Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/small-block-and-big-block-engine-bore-and-stroke-chart-283.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-minor-paint-repair-without-repainting-295.html</guid>
										<title>Service Bulletin: Minor Paint Repair Without Repainting</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-minor-paint-repair-without-repainting-295.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-advantages-of-an-oil-prime-tool-251.html</guid>
										<title>Technical Article:  Advantages of an Oil Prime Tool</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-advantages-of-an-oil-prime-tool-251.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-install-a-bg-speed-demon-basic-87.html</guid>
										<title>Technical Article: How to Install a BG Speed Demon (Basic)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-install-a-bg-speed-demon-basic-87.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-set-up-a-bg-speed-demon-basic-89.html</guid>
										<title>Technical Article: How to Set Up a BG Speed Demon (basic)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-set-up-a-bg-speed-demon-basic-89.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-horsepower-vs-torque-280.html</guid>
										<title>Technical Article:  Horsepower vs. Torque</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-horsepower-vs-torque-280.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/error-codes-on-gm-radios-explained-290.html</guid>
										<title>Error Codes On GM Radios Explained</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/error-codes-on-gm-radios-explained-290.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-removal-of-tight-wheels-277.html</guid>
										<title>Service Bulletin: Removal of Tight Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-removal-of-tight-wheels-277.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-delco-freedom-battery-diagnosis-information-292.html</guid>
										<title>Service Bulletin: Delco Freedom Battery Diagnosis Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-delco-freedom-battery-diagnosis-information-292.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/press-release-batteries-101-how-lead-acid-batteries-work-289.html</guid>
										<title>Press Release: Batteries 101--How Lead-Acid Batteries Work</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/press-release-batteries-101-how-lead-acid-batteries-work-289.html</link>
