<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-4l60-e-4l65-e-automatic-transmission-fluid-leak-from-oil-pump-or-bell-housing-area-276.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-information-regarding-automatic-transmission-shift-lock-control-function-200.html</guid>
										<title>2007 Corvette: Service Bulletin: Information Regarding Automatic Transmission Shift Lock Control Function</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-information-regarding-automatic-transmission-shift-lock-control-function-200.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-new-product-announcement-hydra-matic-6l80-automatic-transmission-204.html</guid>
										<title>2006 Corvette: Service Bulletin: New Product Announcement -- Hydra-Matic 6L80 Automatic Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-new-product-announcement-hydra-matic-6l80-automatic-transmission-204.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-information-hydra-matic-6l80-six-speed-automatic-car-truck-transmission-137.html</guid>
										<title>2008 Corvette: Service Information: Hydra-Matic 6L80 Six-Speed Automatic Car &amp; Truck Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-information-hydra-matic-6l80-six-speed-automatic-car-truck-transmission-137.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-bulletin-clutch-pedal-effort-complaint-166.html</guid>
										<title>2008 Corvette: Service Bulletin:  Clutch Pedal Effort Complaint</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-bulletin-clutch-pedal-effort-complaint-166.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-information-on-2-3-upshift-or-3-2-downshift-clunk-noise-230.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin: Information on 2-3 Upshift or 3-2 Downshift Clunk Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-information-on-2-3-upshift-or-3-2-downshift-clunk-noise-230.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-clutch-pedal-does-not-return-to-up-position-during-shifts-at-high-engine-rpms-353.html</guid>
										<title>2005 Corvette: Service Bulletin: Clutch Pedal Does Not Return to Up Position During Shifts at High Engine RPMs</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-clutch-pedal-does-not-return-to-up-position-during-shifts-at-high-engine-rpms-353.html</link>
