<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-6l80-automatic-transmission-delayed-engagement-from-park-to-drive-or-park-to-reverse-reprogram-transmission-control-module-tcm-275.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-new-product-announcement-hydra-matic-6l80-automatic-transmission-204.html</guid>
										<title>2006 Corvette: Service Bulletin: New Product Announcement -- Hydra-Matic 6L80 Automatic Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-new-product-announcement-hydra-matic-6l80-automatic-transmission-204.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2006-corvette-service-bulletin-diagnostic-information-on-diagnostic-trouble-code-dtc-p0894-and-p1870-215.html</guid>
										<title>2000 - 2006 Corvette: Service Bulletin: Diagnostic Information on Diagnostic Trouble Code (DTC) P0894 and P1870</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2006-corvette-service-bulletin-diagnostic-information-on-diagnostic-trouble-code-dtc-p0894-and-p1870-215.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-customer-satisfaction-program-engine-flywheel-clutch-interference-327.html</guid>
										<title>2006 Corvette: Customer Satisfaction Program: Engine Flywheel/Clutch Interference</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2008-corvette-gm-techlink-6l80-or-6l90-automatic-transmission-shift-conditions-72.html</guid>
										<title>2006 - 2008 Corvette: GM TechLink: 6L80 or 6L90 Automatic Transmission Shift Conditions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2008-corvette-gm-techlink-6l80-or-6l90-automatic-transmission-shift-conditions-72.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-release-of-dexron-vi-automatic-transmission-fluid-atf-354.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: Release of DEXRON VI Automatic Transmission Fluid (ATF)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-release-of-dexron-vi-automatic-transmission-fluid-atf-354.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-mis-machined-transmission-countershaft-snap-352.html</guid>
										<title>2005 Corvette: Service Bulletin: Mis-Machined Transmission Countershaft Snap</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-mis-machined-transmission-countershaft-snap-352.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-bulletin-clutch-pedal-effort-complaint-166.html</guid>
										<title>2008 Corvette: Service Bulletin:  Clutch Pedal Effort Complaint</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-bulletin-clutch-pedal-effort-complaint-166.html</link>
