<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-diagnosis-of-cracked-or-broken-transmission-case-271.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-spongy-clutch-pedal-sticking-to-the-floor-during-hard-acceleration-and-high-rpm-shifts-186.html</guid>
										<title>2005 - 2007 Corvette:  Service Bulletin:  Intermittent Spongy Clutch Pedal Sticking To The Floor During Hard Acceleration And High RPM Shifts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-spongy-clutch-pedal-sticking-to-the-floor-during-hard-acceleration-and-high-rpm-shifts-186.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-new-product-announcement-hydra-matic-6l80-automatic-transmission-204.html</guid>
										<title>2006 Corvette: Service Bulletin: New Product Announcement -- Hydra-Matic 6L80 Automatic Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-new-product-announcement-hydra-matic-6l80-automatic-transmission-204.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2012-corvette-service-bulletin-pi0773-diagnostic-tips-for-dtc-p0796-slip-or-no-4th-5th-or-6th-gear-jul-25-2012-1336.html</guid>
										<title>2006 - 2012 Corvette: Service Bulletin: #PI0773: Diagnostic Tips for DTC P0796, Slip or No 4th, 5th or 6th Gear - (Jul 25, 2012)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2012-corvette-service-bulletin-pi0773-diagnostic-tips-for-dtc-p0796-slip-or-no-4th-5th-or-6th-gear-jul-25-2012-1336.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-6l80-busy-shifting-30-50mph-234.html</guid>
										<title>2007 Corvette:  Service Bulletin: 6L80 Busy Shifting 30-50mph</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-6l80-busy-shifting-30-50mph-234.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2008-corvette-gm-techlink-6l80-or-6l90-automatic-transmission-shift-conditions-72.html</guid>
										<title>2006 - 2008 Corvette: GM TechLink: 6L80 or 6L90 Automatic Transmission Shift Conditions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2008-corvette-gm-techlink-6l80-or-6l90-automatic-transmission-shift-conditions-72.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-manual-transmission-operating-characteristics-195.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: Manual Transmission Operating Characteristics</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-manual-transmission-operating-characteristics-195.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-information-hydra-matic-6l80-six-speed-automatic-car-truck-transmission-137.html</guid>
										<title>2008 Corvette: Service Information: Hydra-Matic 6L80 Six-Speed Automatic Car &amp; Truck Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-information-hydra-matic-6l80-six-speed-automatic-car-truck-transmission-137.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-information-on-2-3-upshift-or-3-2-downshift-clunk-noise-230.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin: Information on 2-3 Upshift or 3-2 Downshift Clunk Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-information-on-2-3-upshift-or-3-2-downshift-clunk-noise-230.html</link>
