										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-keyless-ignition-system-information-346.html</guid>
										<title>2005 Corvette: GM TechLink: Keyless Ignition System Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-keyless-ignition-system-information-346.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-gm-techlink-changer-parked-message-cd-99.html</guid>
										<title>2008 Corvette: GM TechLink: &quot;Changer Parked&quot; Message (CD)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-gm-techlink-changer-parked-message-cd-99.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-chime-sounds-when-key-is-removed-from-ignition-423.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: Chime Sounds When Key is Removed from Ignition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-chime-sounds-when-key-is-removed-from-ignition-423.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-gm-techlink-article-ebcm-condition-111.html</guid>
										<title>2009 Corvette: GM TechLink Article: EBCM Condition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-gm-techlink-article-ebcm-condition-111.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2004-corvette-service-bulletin-twilight-sentinel-automatic-headlamp-control-not-functioning-correctly-or-is-inoperative-218.html</guid>
										<title>2000 - 2004 Corvette: Service Bulletin: Twilight Sentinel/Automatic Headlamp Control Not Functioning Correctly or is Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2004-corvette-service-bulletin-twilight-sentinel-automatic-headlamp-control-not-functioning-correctly-or-is-inoperative-218.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2002-corvette-service-bulletin-dtc-p0757-set-ses-lamp-illuminated-poor-performance-of-transmission-transmission-slipping-432.html</guid>
										<title>1999 - 2002 Corvette: Service Bulletin: DTC P0757 Set, SES Lamp Illuminated, Poor Performance of Transmission, Transmission Slipping</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2002-corvette-service-bulletin-dtc-p0757-set-ses-lamp-illuminated-poor-performance-of-transmission-transmission-slipping-432.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-canadian-corvettes-only-recall-04096-incorrect-air-bag-off-indicator-assembly-348.html</guid>
										<title>2005 (Canadian Corvettes Only): Recall 04096: Incorrect Air Bag Off Indicator Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-canadian-corvettes-only-recall-04096-incorrect-air-bag-off-indicator-assembly-348.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-2013-corvette-customer-satisfaction-program-number-14203-low-beam-headlamps-inoperative-1098.html</guid>
										<title>2008 - 2013 Corvette:  Customer Satisfaction Program:  Number 14203, Low-Beam Headlamps Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-2013-corvette-customer-satisfaction-program-number-14203-low-beam-headlamps-inoperative-1098.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-gm-techlink-instrument-panel-cluster-function-and-diagnosis-385.html</guid>
										<title>1997 - 2004 Corvette: GM TechLink: Instrument Panel Cluster Function and Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-gm-techlink-instrument-panel-cluster-function-and-diagnosis-385.html</link>
