										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-news-corvette-transmission-control-lever-seal-1150.html</guid>
										<title>1956 Corvette Service News:  Corvette Transmission Control Lever Seal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-news-corvette-transmission-control-lever-seal-1150.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-rear-engine-mountings-1955-passenger-6-8-cylinder-with-powerglide-772.html</guid>
										<title>1955 Corvette: Service Bulletin: Rear Engine Mountings 1955 Passenger 6 &amp; 8 Cylinder With Powerglide</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-rear-engine-mountings-1955-passenger-6-8-cylinder-with-powerglide-772.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-vacuum-modulator-spring-throttle-valve-inner-spring-1126.html</guid>
										<title>1954 Corvette:  Service Bulletin:  Vacuum Modulator Spring Throttle Valve Inner Spring</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-vacuum-modulator-spring-throttle-valve-inner-spring-1126.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-clutch-disc-springs-periodic-vibration-991.html</guid>
										<title>1956 Corvette Service Bulletin:  Clutch Disc - Springs - Periodic Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-clutch-disc-springs-periodic-vibration-991.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-excessive-driveline-vibration-941.html</guid>
										<title>1959 Corvette:  Service Bulletin:  Excessive Driveline Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-excessive-driveline-vibration-941.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-technical-article-summary-report-on-changes-to-achieve-improvement-in-corvette-handling-and-ride-85.html</guid>
										<title>1953 - 1954 Corvette: Technical Article: Summary Report on Changes to Achieve Improvement in Corvette Handling and Ride</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-technical-article-summary-report-on-changes-to-achieve-improvement-in-corvette-handling-and-ride-85.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-1959-corvette-service-bulletin-vacuum-modulation-system-inspection-784.html</guid>
										<title>1958 - 1959 Corvette: Service Bulletin: Vacuum Modulation System Inspection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-1959-corvette-service-bulletin-vacuum-modulation-system-inspection-784.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-transmission-identification-information-928.html</guid>
										<title>1962 Corvette:  Service Bulletin:  Transmission Identification Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-transmission-identification-information-928.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-hard-shifting-1216.html</guid>
										<title>1955 Corvette:  Service Bulletin:  Hard Shifting</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-hard-shifting-1216.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-aluminum-powerglide-shift-problems-1037.html</guid>
										<title>1962 Corvette:  Service Bulletin:  Aluminum Powerglide Shift Problems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-aluminum-powerglide-shift-problems-1037.html</link>
