<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-starting-charging-system-267.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-347.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin: Intermittent Service Stability Message On DIC With Only DTC C0561 Symptom 71</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-347.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-instrument-and-interior-lights-198.html</guid>
										<title>2006 Corvette: Electrical Schematic: Instrument and Interior Lights</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-instrument-and-interior-lights-198.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-gm-techlink-electronic-brake-control-module-communication-67.html</guid>
										<title>2009 - 2011 Corvette: GM TechLink:  Electronic Brake Control Module Communication</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-gm-techlink-electronic-brake-control-module-communication-67.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-door-locks-213.html</guid>
										<title>2006 Corvette: Electrical Schematic: Door Locks</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-door-locks-213.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-removal-of-radio-fuse-before-attempting-to-program-reprogram-modules-using-service-program-system-sps-343.html</guid>
										<title>2005 Corvette: Service Bulletin: Removal of Radio Fuse Before Attempting to Program/Reprogram Modules Using Service Program System (SPS)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-removal-of-radio-fuse-before-attempting-to-program-reprogram-modules-using-service-program-system-sps-343.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2011-corvette-gm-techlink-head-up-display-conditions-69.html</guid>
										<title>1999 - 2011 Corvette:  GM TechLink: Head-Up Display Conditions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2011-corvette-gm-techlink-head-up-display-conditions-69.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-exterior-lamps-circuit-206.html</guid>
										<title>2006 Corvette: Electrical Schematic: Exterior Lamps Circuit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-exterior-lamps-circuit-206.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-low-or-completely-discharged-battery-338.html</guid>
										<title>2005 Corvette: GM TechLink: Low or Completely Discharged Battery</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-low-or-completely-discharged-battery-338.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2013-corvette-service-bulletin-pic3379d-hud-head-up-display-information-multiple-conditions-or-questions-nov-27-2012-1331.html</guid>
										<title>1999 - 2013 Corvette: Service Bulletin: #PIC3379D: HUD - Head Up Display Information - Multiple Conditions or Questions - (Nov 27, 2012)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2013-corvette-service-bulletin-pic3379d-hud-head-up-display-information-multiple-conditions-or-questions-nov-27-2012-1331.html</link>
