<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-satellite-radio-circuit-system-266.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-starting-charging-system-267.html</guid>
										<title>2006 Corvette: Electrical Schematic:  Starting - Charging System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-starting-charging-system-267.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-service-bulletin-special-coverage-adjustment-airbag-light-on-1264.html</guid>
										<title>2005 - 2013 Corvette: Service Bulletin: Special Coverage Adjustment - Airbag Light On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-service-bulletin-special-coverage-adjustment-airbag-light-on-1264.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-gm-techlink-cd-player-condition-110.html</guid>
										<title>2008 Corvette: GM TechLink: CD Player Condition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-gm-techlink-cd-player-condition-110.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-setting-the-clock-radio-337.html</guid>
										<title>2005 Corvette: GM TechLink: Setting the Clock Radio</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-setting-the-clock-radio-337.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-camapaign-service-active-handling-92.html</guid>
										<title>2005 - 2006 Corvette: Camapaign: Service Active Handling</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-camapaign-service-active-handling-92.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-low-or-completely-discharged-battery-338.html</guid>
										<title>2005 Corvette: GM TechLink: Low or Completely Discharged Battery</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-low-or-completely-discharged-battery-338.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2010-corvette-service-bulletin-pic5346a-normal-characteristic-unable-to-answer-a-second-incoming-bluetooth-call-or-continues-to-ring-after-answering-a-second-incoming-call-1329.html</guid>
										<title>2009 - 2010 Corvette: Service Bulletin: #PIC5346A: Normal Characteristic - Unable To Answer a Second Incoming Bluetooth call or Continues To Ring After Answering a Second Incoming Call</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-ac-compressor-211.html</guid>
										<title>2006 Corvette: Electrical Schematic: AC Compressor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-ac-compressor-211.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-gm-techlink-electronic-brake-control-module-communication-67.html</guid>
										<title>2009 - 2011 Corvette: GM TechLink:  Electronic Brake Control Module Communication</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-gm-techlink-electronic-brake-control-module-communication-67.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-gm-techlink-article-no-fob-detected-message-9.html</guid>
										<title>2005 - 2013 Corvette: GM TechLink Article: No Fob Detected Message</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-gm-techlink-article-no-fob-detected-message-9.html</link>
