<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-base-radio-system-264.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2010-corvette-gm-techlink-corvette-battery-charger-accessory-65.html</guid>
										<title>2010 Corvette:  GM TechLink: Corvette Battery Charger Accessory</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2010-corvette-gm-techlink-corvette-battery-charger-accessory-65.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-information-transmitter-programming-domestic-and-japan-135.html</guid>
										<title>2006 Corvette: Service Information: Transmitter Programming (Domestic and Japan)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-information-transmitter-programming-domestic-and-japan-135.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-misfire-dtcs-p0300-p1380-p1381-and-catalytic-converter-damage-due-to-installation-of-alarm-systems-194.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: Misfire DTCs P0300, P1380, P1381 and Catalytic Converter Damage Due to Installation of Alarm Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-misfire-dtcs-p0300-p1380-p1381-and-catalytic-converter-damage-due-to-installation-of-alarm-systems-194.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-satellite-radio-circuit-system-266.html</guid>
										<title>2006 Corvette: Electrical Schematic: Satellite Radio Circuit System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-satellite-radio-circuit-system-266.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-ac-compressor-211.html</guid>
										<title>2006 Corvette: Electrical Schematic: AC Compressor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-ac-compressor-211.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-keyless-ignition-system-information-346.html</guid>
										<title>2005 Corvette: GM TechLink: Keyless Ignition System Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-keyless-ignition-system-information-346.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-diagnostic-trouble-codes-220.html</guid>
										<title>2006 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-diagnostic-trouble-codes-220.html</link>
