<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-upper-radiator-hose-alignment-25.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-service-bulletin-cooling-system-restrictions-symptoms-and-diagnosis-1131.html</guid>
										<title>1963 - 1982 Corvette:  Service Bulletin:  Cooling System Restrictions - Symptoms and Diagnosis</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-water-entry-into-fuel-tank-1092-1125.html</guid>
										<title>1968 - 1969 Corvette:  Engineering Service Letter:  Water Entry Into Fuel Tank (#1092)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-water-entry-into-fuel-tank-1092-1125.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-1974-corvette-service-bulletin-engine-overheat-due-to-blocked-coolant-passage-in-the-cylinder-head-1115.html</guid>
										<title>1973 - 1974 Corvette:  Service Bulletin:  Engine Overheat Due to Blocked Coolant Passage in the Cylinder Head</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-1974-corvette-service-bulletin-engine-overheat-due-to-blocked-coolant-passage-in-the-cylinder-head-1115.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1976-corvette-service-bulletin-air-conditioning-compressor-drive-belt-to-radiator-hose-interference-721.html</guid>
										<title>1969 - 1976 Corvette: Service Bulletin: Air Conditioning Compressor Drive Belt to Radiator Hose Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1976-corvette-service-bulletin-air-conditioning-compressor-drive-belt-to-radiator-hose-interference-721.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-heat-shielding-132.html</guid>
										<title>1973 Corvette: Service Bulletin:  Exhaust Manifold Heat Shielding</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-heat-shielding-132.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-187.html</guid>
										<title>1973 Corvette: Service Bulletin: Exhaust Manifold to Air Conditioning Refrigerant Hose Clearance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-187.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</guid>
										<title>1973 Corvette:  Electrical Schematic: Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-tune-up-specification-change-893.html</guid>
										<title>1968 Corvette:  Service News:  Tune-up Specification Change</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-tune-up-specification-change-893.html</link>
