<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-technical-article-the-other-corvette-body-builder-a-o-smith-helps-st-louis-keep-up-with-production-248.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-back-window-753.html</guid>
										<title>1964 Corvette: Service News: Back Window</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-back-window-753.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-service-news-corvette-coupe-body-rework-for-larger-racing-tires-rear-wheels-874.html</guid>
										<title>1963 - 1967 Corvette: Service News: Corvette Coupe Body Rework for Larger Racing Tires (Rear Wheels)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-service-news-corvette-coupe-body-rework-for-larger-racing-tires-rear-wheels-874.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-inter-organization-letter-difficulty-in-raising-door-window-925.html</guid>
										<title>1963 Corvette:  Inter-Organization Letter:  Difficulty in Raising Door Window</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-inter-organization-letter-difficulty-in-raising-door-window-925.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-service-bulletin-door-glass-outer-seal-strip-replacement-758.html</guid>
										<title>1963 - 1964 Corvette: Service Bulletin: Door Glass Outer Seal Strip Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-service-bulletin-door-glass-outer-seal-strip-replacement-758.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-corvette-hood-support-safety-hole-898.html</guid>
										<title>1964 Corvette:  Service News:  Corvette Hood Support Safety Hole</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-corvette-hood-support-safety-hole-898.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-chevrolet-engineering-letter-exterior-paint-process-249.html</guid>
										<title>1963  - 1967 Corvette: Chevrolet Engineering Letter: Exterior Paint Process</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-chevrolet-engineering-letter-exterior-paint-process-249.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-rattle-in-door-when-window-partially-down-754.html</guid>
										<title>1964 Corvette: Service Bulletin: Rattle in Door When Window Partially Down</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-rattle-in-door-when-window-partially-down-754.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-gm-of-canada-hood-lock-spring-assembly-871.html</guid>
										<title>1963 Corvette: Service Bulletin - GM of Canada: Hood Lock Spring Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-gm-of-canada-hood-lock-spring-assembly-871.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-difficulty-in-raising-door-window-756.html</guid>
										<title>1963 Corvette: Service Bulletin: Difficulty in Raising Door Window</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-difficulty-in-raising-door-window-756.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-product-engineering-technical-information-loosening-of-door-window-regulator-assembly-1013.html</guid>
										<title>1963 Corvette:  Product Engineering Technical Information:  Loosening of Door Window Regulator Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-product-engineering-technical-information-loosening-of-door-window-regulator-assembly-1013.html</link>
