<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-riveting-experience-home-restorer-s-guide-to-installing-soft-aluminum-rivets-on-your-corvette-245.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/determining-the-resistance-value-of-the-ignition-key-resistor-pellet-291.html</guid>
										<title>Determining the Resistance Value of the Ignition Key Resistor Pellet</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/determining-the-resistance-value-of-the-ignition-key-resistor-pellet-291.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/chevrolet-service-bulletin-information-on-proper-tire-pressure-202.html</guid>
										<title>Chevrolet Service Bulletin: Information on Proper Tire Pressure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/chevrolet-service-bulletin-information-on-proper-tire-pressure-202.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-minor-paint-repair-without-repainting-295.html</guid>
										<title>Service Bulletin: Minor Paint Repair Without Repainting</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-minor-paint-repair-without-repainting-295.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-timing-and-vacuum-advance-101-253.html</guid>
										<title>Technical Article:  Timing and Vacuum Advance 101</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-timing-and-vacuum-advance-101-253.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-horsepower-vs-torque-280.html</guid>
										<title>Technical Article:  Horsepower vs. Torque</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-horsepower-vs-torque-280.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-delco-freedom-battery-diagnosis-information-292.html</guid>
										<title>Service Bulletin: Delco Freedom Battery Diagnosis Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-delco-freedom-battery-diagnosis-information-292.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-long-term-winter-corvette-storage-299.html</guid>
										<title>Technical Article: Long Term / Winter Corvette Storage</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-long-term-winter-corvette-storage-299.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/big-block-chevrolet-engine-crankshaft-specifications-288.html</guid>
										<title>Big Block Chevrolet Engine Crankshaft Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/big-block-chevrolet-engine-crankshaft-specifications-288.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/engine-casting-numbers-chevrolet-v8-passenger-cars-287.html</guid>
										<title>Engine Casting Numbers: Chevrolet V8 Passenger Cars</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/engine-casting-numbers-chevrolet-v8-passenger-cars-287.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/paint-orange-peel-as-it-applies-to-corvette-paint-quality-296.html</guid>
										<title>Paint: Orange Peel as it Applies to Corvette Paint Quality</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/paint-orange-peel-as-it-applies-to-corvette-paint-quality-296.html</link>
