										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-power-windows-special-policy-992.html</guid>
										<title>1965 Corvette:  Service Bulletin:  Power Windows - Special Policy</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-power-windows-special-policy-992.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-distributor-breaker-point-burning-54.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Distributor Breaker Point Burning</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-distributor-breaker-point-burning-54.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-transistorized-voltage-regulator-failures-1219.html</guid>
										<title>1965 Corvette:  Service Bulletin:  Transistorized Voltage Regulator Failures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-transistorized-voltage-regulator-failures-1219.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1967-corvette-delco-remy-service-bulletin-ignition-systems-940.html</guid>
										<title>1964 - 1967 Corvette:  Delco-Remy Service Bulletin:  Ignition Systems</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-chevrolet-service-news-two-unit-voltage-regulator-diagnosis-and-adjustment-1258.html</guid>
										<title>1963 - 1967 Corvette:  Chevrolet Service News:  Two-Unit Voltage Regulator Diagnosis and Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-chevrolet-service-news-two-unit-voltage-regulator-diagnosis-and-adjustment-1258.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-chevrolet-parts-and-accessories-bulletin-delcotron-generator-replacement-parts-1007.html</guid>
										<title>1963 Corvette:  Chevrolet Parts and Accessories Bulletin:  Delcotron Generator Replacement Parts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-chevrolet-parts-and-accessories-bulletin-delcotron-generator-replacement-parts-1007.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1966-corvette-service-news-corvette-power-antenna-replacement-965.html</guid>
										<title>1965 - 1966 Corvette:  Service News:  Corvette Power Antenna Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1966-corvette-service-news-corvette-power-antenna-replacement-965.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-inter-organizationl-letter-high-speed-warning-buzzer-deletion-737.html</guid>
										<title>1963 Corvette: Inter-Organizationl Letter: High-Speed Warning Buzzer Deletion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-inter-organizationl-letter-high-speed-warning-buzzer-deletion-737.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-servicing-the-breakerless-ignition-system-916.html</guid>
										<title>1964 Corvette:  Service News:  Servicing the Breakerless Ignition System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-servicing-the-breakerless-ignition-system-916.html</link>
