<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-technical-article-radiator-replacement-242.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-rpo-l-76-327-365-h-p-holley-carburetor-parts-changes-115.html</guid>
										<title>1965 Corvette: Engineering Service Letter: RPO L-76 327-365 H.P. Holley Carburetor Parts Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-rpo-l-76-327-365-h-p-holley-carburetor-parts-changes-115.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1965-corvette-technical-article-30-30-solid-lifter-cam-valve-adjustment-733.html</guid>
										<title>1964 - 1965 Corvette: Technical Article: &quot;30-30&quot; Solid Lifter Cam Valve Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1965-corvette-technical-article-30-30-solid-lifter-cam-valve-adjustment-733.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-water-pump-pulley-failures-84.html</guid>
										<title>1966 Corvette: Service Bulletin: Water Pump Pulley Failures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-water-pump-pulley-failures-84.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-engine-surge-1966-427ci-corvettes-with-holley-carburetor-729.html</guid>
										<title>1966 Corvette: Service Bulletin: Engine Surge - 1966 427ci Corvettes with Holley Carburetor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-engine-surge-1966-427ci-corvettes-with-holley-carburetor-729.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-engine-removal-revised-157.html</guid>
										<title>1965 Corvette: Service News:  Engine Removal Revised</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-engine-removal-revised-157.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-service-news-radiator-lower-hose-replacement-53.html</guid>
										<title>1963 - 1964 Corvette: Service News:  Radiator Lower Hose Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-service-news-radiator-lower-hose-replacement-53.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-product-data-book-radiator-grille-supports-140.html</guid>
										<title>1966 Corvette:  Product Data Book:  Radiator Grille Supports</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-product-data-book-radiator-grille-supports-140.html</link>
