<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-knowing-how-your-1963-1982-corvette-s-cooling-system-can-prevent-a-steaming-summer-241.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-engine-coolant-usage-anti-freeze-specs-change-675.html</guid>
										<title>1982 Corvette: Service Bulletin: Engine Coolant Usage Anti-Freeze Specs Change</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-engine-coolant-usage-anti-freeze-specs-change-675.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-fuel-filter-953.html</guid>
										<title>1978 Corvette:  Service Bulletin:  Fuel Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-fuel-filter-953.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-product-data-book-radiator-grille-supports-140.html</guid>
										<title>1966 Corvette:  Product Data Book:  Radiator Grille Supports</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-product-data-book-radiator-grille-supports-140.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-187.html</guid>
										<title>1973 Corvette: Service Bulletin: Exhaust Manifold to Air Conditioning Refrigerant Hose Clearance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-187.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-filter-usage-and-installation-938.html</guid>
										<title>1982 Corvette:  Service News:  Fuel Filter Usage and Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-filter-usage-and-installation-938.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-heat-shield-starting-motor-solenoid-907.html</guid>
										<title>1968 - 1969 Corvette:  Engineering Service Letter:  Heat Shield - Starting Motor Solenoid</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-heat-shield-starting-motor-solenoid-907.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-engine-removal-revised-157.html</guid>
										<title>1965 Corvette: Service News:  Engine Removal Revised</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-engine-removal-revised-157.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-leakage-at-oil-filter-1081.html</guid>
										<title>1968 Corvette Service Bulletin:  Leakage at Oil Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-leakage-at-oil-filter-1081.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1969-corvette-tech-article-building-427-engines-corvette-news-1274.html</guid>
										<title>1966 - 1969 Corvette: Tech Article:  Building 427 Engines - Corvette News</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1969-corvette-tech-article-building-427-engines-corvette-news-1274.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-overheating-at-idle-730.html</guid>
										<title>1966 Corvette: Engineering Service Letter: Overheating at Idle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-overheating-at-idle-730.html</link>
