<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-technical-article-adjusting-the-fast-idle-speed-239.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-1965-corvette-396-425-h-p-rpo-l-78-incorrect-build-28.html</guid>
										<title>1965 Corvette: Engineering Service Letter: 1965 Corvette 396-425 H.P. RPO L-78 Incorrect Build</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-1965-corvette-396-425-h-p-rpo-l-78-incorrect-build-28.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-interim-production-changes-1024.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Interim Production Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-interim-production-changes-1024.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-engine-surge-1966-427ci-corvettes-with-holley-carburetor-729.html</guid>
										<title>1966 Corvette: Service Bulletin: Engine Surge - 1966 427ci Corvettes with Holley Carburetor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-engine-surge-1966-427ci-corvettes-with-holley-carburetor-729.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1964-corvette-parts-mart-pistons-with-pins-piston-ring-specifications-1034.html</guid>
										<title>1953 - 1964 Corvette:  Parts Mart:  Pistons with Pins - Piston Ring Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1964-corvette-parts-mart-pistons-with-pins-piston-ring-specifications-1034.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-technical-information-holley-carburetor-changes-on-396-cu-in-engines-425-h-p-1010.html</guid>
										<title>1965 Corvette: Engineering Technical Information:  Holley Carburetor Changes on 396 CU. IN. Engines - 425 H.P.</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-technical-information-holley-carburetor-changes-on-396-cu-in-engines-425-h-p-1010.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-knowing-how-your-1963-1982-corvette-s-cooling-system-can-prevent-a-steaming-summer-241.html</guid>
										<title>1963 - 1982 Corvette: Technical Article: Knowing How Your 1963 - 1982 Corvette`s Cooling System Can Prevent a Steaming Summer</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-knowing-how-your-1963-1982-corvette-s-cooling-system-can-prevent-a-steaming-summer-241.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-service-news-radiator-lower-hose-replacement-53.html</guid>
										<title>1963 - 1964 Corvette: Service News:  Radiator Lower Hose Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-service-news-radiator-lower-hose-replacement-53.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1965-corvette-service-bulletin-drive-line-noise-1084.html</guid>
										<title>1963 - 1965 Corvette:  Service Bulletin:  Drive Line Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1965-corvette-service-bulletin-drive-line-noise-1084.html</link>
