<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-leak-less-swapping-the-centerhead-in-your-corvette-and-keeping-leaks-at-bay-238.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-air-conditioning-system-maintenance-and-repair-297.html</guid>
										<title>Technical Article: Air Conditioning System Maintenance and Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-air-conditioning-system-maintenance-and-repair-297.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/all-corvettes-service-bulletin-removal-of-tight-wheels-1189.html</guid>
										<title>All Corvettes:  Service Bulletin:  Removal of Tight Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/all-corvettes-service-bulletin-removal-of-tight-wheels-1189.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/engine-casting-numbers-chevrolet-v8-passenger-cars-287.html</guid>
										<title>Engine Casting Numbers: Chevrolet V8 Passenger Cars</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/engine-casting-numbers-chevrolet-v8-passenger-cars-287.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-set-up-a-bg-speed-demon-basic-89.html</guid>
										<title>Technical Article: How to Set Up a BG Speed Demon (basic)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-set-up-a-bg-speed-demon-basic-89.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-synthetic-oil-use-282.html</guid>
										<title>Technical Article:  Synthetic Oil Use</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-synthetic-oil-use-282.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-install-a-bg-speed-demon-basic-87.html</guid>
										<title>Technical Article: How to Install a BG Speed Demon (Basic)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-install-a-bg-speed-demon-basic-87.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-repair-rebuild-your-alternator-90.html</guid>
										<title>Technical Article: How to Repair &amp; Rebuild your Alternator</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-repair-rebuild-your-alternator-90.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-long-term-winter-corvette-storage-299.html</guid>
										<title>Technical Article: Long Term / Winter Corvette Storage</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-long-term-winter-corvette-storage-299.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-removal-of-tight-wheels-277.html</guid>
										<title>Service Bulletin: Removal of Tight Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-removal-of-tight-wheels-277.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-evaluation-k-n-air-filter-vs-the-green-filter-285.html</guid>
										<title>Product Evaluation: K&N Air Filter vs. The Green Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-evaluation-k-n-air-filter-vs-the-green-filter-285.html</link>
