<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-6l80-busy-shifting-30-50mph-234.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2012-corvette-service-bulletin-pi0773-diagnostic-tips-for-dtc-p0796-slip-or-no-4th-5th-or-6th-gear-jul-25-2012-1336.html</guid>
										<title>2006 - 2012 Corvette: Service Bulletin: #PI0773: Diagnostic Tips for DTC P0796, Slip or No 4th, 5th or 6th Gear - (Jul 25, 2012)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2012-corvette-service-bulletin-pi0773-diagnostic-tips-for-dtc-p0796-slip-or-no-4th-5th-or-6th-gear-jul-25-2012-1336.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-information-on-2-3-upshift-or-3-2-downshift-clunk-noise-230.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin: Information on 2-3 Upshift or 3-2 Downshift Clunk Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-information-on-2-3-upshift-or-3-2-downshift-clunk-noise-230.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-release-of-dexron-vi-automatic-transmission-fluid-atf-354.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: Release of DEXRON VI Automatic Transmission Fluid (ATF)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-release-of-dexron-vi-automatic-transmission-fluid-atf-354.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-bulletin-clutch-pedal-effort-complaint-166.html</guid>
										<title>2008 Corvette: Service Bulletin:  Clutch Pedal Effort Complaint</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-bulletin-clutch-pedal-effort-complaint-166.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-diagnostic-tips-for-automatic-transmission-dtc-p0756-second-third-fourth-gear-start-269.html</guid>
										<title>2007 Corvette: Service Bulletin: Diagnostic Tips for Automatic Transmission DTC P0756, Second, Third, Fourth Gear Start</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-diagnostic-tips-for-automatic-transmission-dtc-p0756-second-third-fourth-gear-start-269.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-diagnosis-of-cracked-or-broken-transmission-case-271.html</guid>
										<title>2006 Corvette: Service Bulletin:  Diagnosis of Cracked or Broken Transmission Case</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-diagnosis-of-cracked-or-broken-transmission-case-271.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-information-on-driveline-clunk-noise-when-shifting-between-park-and-drive-park-and-reverse-or-drive-and-reverse-214.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin: Information on Driveline Clunk Noise When Shifting Between PARK and DRIVE, PARK and REVERSE or DRIVE and REVERSE</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-information-on-driveline-clunk-noise-when-shifting-between-park-and-drive-park-and-reverse-or-drive-and-reverse-214.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-automatic-transmission-busy-shifting-mil-illuminated-dtc-p1751-350.html</guid>
										<title>2006 Corvette: Service Bulletin: Automatic Transmission, Busy Shifting, MIL Illuminated, DTC P1751</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-automatic-transmission-busy-shifting-mil-illuminated-dtc-p1751-350.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-6l80-automatic-transmission-delayed-engagement-from-park-to-drive-or-park-to-reverse-reprogram-transmission-control-module-tcm-275.html</guid>
										<title>2006 Corvette: Service Bulletin: 6L80 Automatic Transmission Delayed Engagement From PARK to DRIVE or PARK to REVERSE (Reprogram Transmission Control Module (TCM))</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-6l80-automatic-transmission-delayed-engagement-from-park-to-drive-or-park-to-reverse-reprogram-transmission-control-module-tcm-275.html</link>
