<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-diagnostic-trouble-codes-228.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-rear-window-defogger-inoperative-413.html</guid>
										<title>1998 Corvette Convertible: Service Bulletin: Rear Window Defogger Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-rear-window-defogger-inoperative-413.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-recall-electronic-column-lock-system-418.html</guid>
										<title>1997 - 2004 Corvette: Recall: Electronic Column Lock System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-recall-electronic-column-lock-system-418.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-diagnostic-trouble-codes-225.html</guid>
										<title>2004 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-diagnostic-trouble-codes-225.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-various-driveability-issues-repair-secure-wire-harness-at-pcm-414.html</guid>
										<title>1997 Corvette: Service Bulletin: Various Driveability Issues (Repair/Secure Wire Harness at PCM)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-various-driveability-issues-repair-secure-wire-harness-at-pcm-414.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-chime-sounds-when-key-is-removed-from-ignition-423.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: Chime Sounds When Key is Removed from Ignition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-chime-sounds-when-key-is-removed-from-ignition-423.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-traction-control-handling-lamp-on-407.html</guid>
										<title>2001 Corvette: Service Bulletin: Traction Control/Handling Lamp On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-traction-control-handling-lamp-on-407.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-bulletin-misfire-dtcs-and-catalytic-converter-damage-due-to-installation-of-alarm-systems-419.html</guid>
										<title>1997 - 2003 Corvette: Service Bulletin: Misfire DTCs and Catalytic Converter Damage Due to Installation of Alarm Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-bulletin-misfire-dtcs-and-catalytic-converter-damage-due-to-installation-of-alarm-systems-419.html</link>
