<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-diagnostic-trouble-codes-227.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-no-crank-prndl-inoperative-342.html</guid>
										<title>2005 Corvette: GM TechLink: No Crank, PRNDL Inoperative</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-traction-control-handling-lamp-on-407.html</guid>
										<title>2001 Corvette: Service Bulletin: Traction Control/Handling Lamp On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-traction-control-handling-lamp-on-407.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-service-bulletin-erratic-fuel-gauge-reading-reprogram-the-pcm-406.html</guid>
										<title>2002 Corvette: Service Bulletin: Erratic Fuel Gauge Reading (Reprogram the PCM)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-service-bulletin-erratic-fuel-gauge-reading-reprogram-the-pcm-406.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-diagnostic-trouble-codes-421.html</guid>
										<title>1997 - 2000 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-diagnostic-trouble-codes-421.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-fuel-pump-noise-coming-from-fuel-pump-tank-replace-fuel-pump-assembly-425.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Fuel Pump Noise Coming From Fuel Pump/Tank (Replace Fuel Pump Assembly)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-fuel-pump-noise-coming-from-fuel-pump-tank-replace-fuel-pump-assembly-425.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-electrical-features-information-1321.html</guid>
										<title>2000 Corvette:  Electrical Features Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-electrical-features-information-1321.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2004-corvette-service-bulletin-twilight-sentinel-automatic-headlamp-control-not-functioning-correctly-or-is-inoperative-218.html</guid>
										<title>2000 - 2004 Corvette: Service Bulletin: Twilight Sentinel/Automatic Headlamp Control Not Functioning Correctly or is Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2004-corvette-service-bulletin-twilight-sentinel-automatic-headlamp-control-not-functioning-correctly-or-is-inoperative-218.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2008-corvette-service-campaign-unwanted-repeat-calls-to-onstar-13.html</guid>
										<title>2004 - 2008 Corvette: Service Campaign: Unwanted Repeat Calls to OnStar</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2008-corvette-service-campaign-unwanted-repeat-calls-to-onstar-13.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-rear-window-defogger-inoperative-413.html</guid>
										<title>1998 Corvette Convertible: Service Bulletin: Rear Window Defogger Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-rear-window-defogger-inoperative-413.html</link>
