<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-diagnostic-trouble-codes-224.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-electrical-features-information-1321.html</guid>
										<title>2000 Corvette:  Electrical Features Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-electrical-features-information-1321.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-sir-diagnostics-and-procedures-to-prevent-codes-16-and-26-due-to-corrosion-revised-561.html</guid>
										<title>1990 Corvette: Service Bulletin: SIR Diagnostics and Procedures to Prevent Codes 16 and 26 Due to Corrosion Revised</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-sir-diagnostics-and-procedures-to-prevent-codes-16-and-26-due-to-corrosion-revised-561.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-chime-sounds-when-key-is-removed-from-ignition-423.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: Chime Sounds When Key is Removed from Ignition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-chime-sounds-when-key-is-removed-from-ignition-423.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-diagnostic-trouble-codes-228.html</guid>
										<title>2002 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-diagnostic-trouble-codes-228.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-news-corvette-illuminated-check-gauges-light-882.html</guid>
										<title>1997 - 1999 Corvette:  Service News:  Corvette Illuminated Check Gauges Light</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-news-corvette-illuminated-check-gauges-light-882.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-diagnostic-trouble-codes-223.html</guid>
										<title>1998 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-diagnostic-trouble-codes-223.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-service-bulletin-inaccurate-erratic-fuel-level-gauge-readings-420.html</guid>
										<title>1997 - 2000 Corvette: Service Bulletin: Inaccurate/Erratic Fuel Level Gauge Readings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-service-bulletin-inaccurate-erratic-fuel-level-gauge-readings-420.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-diagnostic-trouble-codes-421.html</guid>
										<title>1997 - 2000 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-diagnostic-trouble-codes-421.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-pairing-key-fob-to-car-1284.html</guid>
										<title>2009 Corvette:  Pairing Key Fob to Car</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-pairing-key-fob-to-car-1284.html</link>
