<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-diagnostic-trouble-codes-223.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-various-driveability-issues-repair-secure-wire-harness-at-pcm-414.html</guid>
										<title>1997 Corvette: Service Bulletin: Various Driveability Issues (Repair/Secure Wire Harness at PCM)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-various-driveability-issues-repair-secure-wire-harness-at-pcm-414.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-diagnostic-trouble-codes-228.html</guid>
										<title>2002 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-diagnostic-trouble-codes-228.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-abs-diagnostic-trouble-codes-229.html</guid>
										<title>2000 Corvette: ABS Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-abs-diagnostic-trouble-codes-229.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2008-corvette-service-campaign-unwanted-repeat-calls-to-onstar-13.html</guid>
										<title>2004 - 2008 Corvette: Service Campaign: Unwanted Repeat Calls to OnStar</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2008-corvette-service-campaign-unwanted-repeat-calls-to-onstar-13.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-2000-corvette-service-bulletin-electronic-steering-column-lock-may-refuse-to-operate-dic-service-message-displayed-426.html</guid>
										<title>1997 - 1998, 2000 Corvette: Service Bulletin: Electronic Steering Column Lock May Refuse to Operate - DIC Service Message Displayed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-2000-corvette-service-bulletin-electronic-steering-column-lock-may-refuse-to-operate-dic-service-message-displayed-426.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2004-corvette-service-bulletin-twilight-sentinel-automatic-headlamp-control-not-functioning-correctly-or-is-inoperative-218.html</guid>
										<title>2000 - 2004 Corvette: Service Bulletin: Twilight Sentinel/Automatic Headlamp Control Not Functioning Correctly or is Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2004-corvette-service-bulletin-twilight-sentinel-automatic-headlamp-control-not-functioning-correctly-or-is-inoperative-218.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2011-corvette-gm-techlink-head-up-display-conditions-69.html</guid>
										<title>1999 - 2011 Corvette:  GM TechLink: Head-Up Display Conditions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2011-corvette-gm-techlink-head-up-display-conditions-69.html</link>
