<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-corvette-diagnostic-trouble-codes-222.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2004-corvette-service-bulletin-twilight-sentinel-automatic-headlamp-control-not-functioning-correctly-or-is-inoperative-218.html</guid>
										<title>2000 - 2004 Corvette: Service Bulletin: Twilight Sentinel/Automatic Headlamp Control Not Functioning Correctly or is Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2004-corvette-service-bulletin-twilight-sentinel-automatic-headlamp-control-not-functioning-correctly-or-is-inoperative-218.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-bulletin-misfire-dtcs-and-catalytic-converter-damage-due-to-installation-of-alarm-systems-419.html</guid>
										<title>1997 - 2003 Corvette: Service Bulletin: Misfire DTCs and Catalytic Converter Damage Due to Installation of Alarm Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-bulletin-misfire-dtcs-and-catalytic-converter-damage-due-to-installation-of-alarm-systems-419.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-erratic-fuel-gauge-readings-415.html</guid>
										<title>1997 Corvette: Service Bulletin: Erratic Fuel Gauge Readings</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2013-corvette-service-bulletin-pic3379d-hud-head-up-display-information-multiple-conditions-or-questions-nov-27-2012-1331.html</guid>
										<title>1999 - 2013 Corvette: Service Bulletin: #PIC3379D: HUD - Head Up Display Information - Multiple Conditions or Questions - (Nov 27, 2012)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2013-corvette-service-bulletin-pic3379d-hud-head-up-display-information-multiple-conditions-or-questions-nov-27-2012-1331.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-fuel-pump-noise-coming-from-fuel-pump-tank-replace-fuel-pump-assembly-425.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Fuel Pump Noise Coming From Fuel Pump/Tank (Replace Fuel Pump Assembly)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-fuel-pump-noise-coming-from-fuel-pump-tank-replace-fuel-pump-assembly-425.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-inoperative-remote-keyless-entry-system-and-or-tire-pressure-monitor-system-424.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Inoperative Remote Keyless Entry System and/or Tire Pressure Monitor System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-inoperative-remote-keyless-entry-system-and-or-tire-pressure-monitor-system-424.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-various-driveability-issues-repair-secure-wire-harness-at-pcm-414.html</guid>
										<title>1997 Corvette: Service Bulletin: Various Driveability Issues (Repair/Secure Wire Harness at PCM)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-various-driveability-issues-repair-secure-wire-harness-at-pcm-414.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-service-bulletin-erratic-fuel-gauge-reading-reprogram-the-pcm-406.html</guid>
										<title>2002 Corvette: Service Bulletin: Erratic Fuel Gauge Reading (Reprogram the PCM)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-service-bulletin-erratic-fuel-gauge-reading-reprogram-the-pcm-406.html</link>
