<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-diagnostic-trouble-codes-220.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-engine-controls-207.html</guid>
										<title>2006 Corvette: Electrical Schematic: Engine Controls</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-engine-controls-207.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-actual-outside-temperature-does-not-match-temperature-reading-on-inter-display-normal-operating-characteristic-341.html</guid>
										<title>2005 Corvette: Service Bulletin: Actual Outside Temperature Does Not Match Temperature Reading On Inter Display - Normal Operating Characteristic</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-actual-outside-temperature-does-not-match-temperature-reading-on-inter-display-normal-operating-characteristic-341.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-setting-the-clock-radio-337.html</guid>
										<title>2005 Corvette: GM TechLink: Setting the Clock Radio</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-setting-the-clock-radio-337.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-service-bulletin-15643a-special-coverage-airbag-light-on-feb-2-2017-1328.html</guid>
										<title>2005 - 2013 Corvette: Service Bulletin: #15643A: Special Coverage - Airbag Light On - (Feb 2, 2017)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-service-bulletin-15643a-special-coverage-airbag-light-on-feb-2-2017-1328.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-starting-charging-system-267.html</guid>
										<title>2006 Corvette: Electrical Schematic:  Starting - Charging System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-starting-charging-system-267.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-service-bulletin-stabilitrak-active-handling-light-on-service-stabilitrak-active-handling-message-on-dic-152.html</guid>
										<title>2005 - 2008: Service Bulletin:  Stabilitrak/Active Handling Light On, Service Stabilitrak/Active Handling Message on DIC</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2012-corvette-gm-techlink-article-noticeable-difference-in-audio-volume-level-38.html</guid>
										<title>2005 - 2012 Corvette: GM TechLink Article: Noticeable Difference in Audio Volume Level</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2012-corvette-gm-techlink-article-noticeable-difference-in-audio-volume-level-38.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-trip-odometer-operation-98.html</guid>
										<title>2005 - 2008 Corvette: GM TechLink: Trip Odometer Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-trip-odometer-operation-98.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-instrument-and-interior-lights-198.html</guid>
										<title>2006 Corvette: Electrical Schematic: Instrument and Interior Lights</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-instrument-and-interior-lights-198.html</link>
