<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-replacement-of-isolation-diodes-217.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-product-safety-campaign-84c22-relocation-of-cruise-control-servo-assembly-924.html</guid>
										<title>1984 Corvette:  Recall:  Product Safety Campaign 84C22 Relocation of Cruise Control Servo Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-product-safety-campaign-84c22-relocation-of-cruise-control-servo-assembly-924.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-ac-compressor-specifications-491.html</guid>
										<title>1990 - 1995 Corvette | ZR-1: AC Compressor Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-ac-compressor-specifications-491.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-damaged-ecm-pcm-mis-diagnosis-due-to-incorrect-tap-testing-procedures-690.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Damaged ECM/PCM Mis-Diagnosis Due to Incorrect &quot;Tap-Testing&quot; Procedures</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-information-service-tips-for-supplemental-inflatable-restraint-sir-160.html</guid>
										<title>1990 - 1991 Corvette: Service Information: Service Tips for Supplemental Inflatable Restraint (SIR)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-information-service-tips-for-supplemental-inflatable-restraint-sir-160.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-positive-battery-cable-routing-881.html</guid>
										<title>1984 Corvette: Recall: Positive Battery Cable Routing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-positive-battery-cable-routing-881.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-new-heater-and-air-condition-control-head-assembly-1028.html</guid>
										<title>1986 - 1988 Corvette:  Service Bulletin:  New Heater and Air Condition Control Head Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-new-heater-and-air-condition-control-head-assembly-1028.html</link>
