<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2006-corvette-service-bulletin-diagnostic-information-on-diagnostic-trouble-code-dtc-p0894-and-p1870-215.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-information-on-driveline-clunk-noise-when-shifting-between-park-and-drive-park-and-reverse-or-drive-and-reverse-214.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin: Information on Driveline Clunk Noise When Shifting Between PARK and DRIVE, PARK and REVERSE or DRIVE and REVERSE</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-information-on-driveline-clunk-noise-when-shifting-between-park-and-drive-park-and-reverse-or-drive-and-reverse-214.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-6l80-automatic-transmission-delayed-engagement-from-park-to-drive-or-park-to-reverse-reprogram-transmission-control-module-tcm-275.html</guid>
										<title>2006 Corvette: Service Bulletin: 6L80 Automatic Transmission Delayed Engagement From PARK to DRIVE or PARK to REVERSE (Reprogram Transmission Control Module (TCM))</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-6l80-automatic-transmission-delayed-engagement-from-park-to-drive-or-park-to-reverse-reprogram-transmission-control-module-tcm-275.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2001-corvette-service-bulletin-park-neutral-position-switch-connector-cannot-be-removed-437.html</guid>
										<title>1997 - 2001 Corvette: Service Bulletin: Park/Neutral Position Switch Connector Cannot Be Removed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2001-corvette-service-bulletin-park-neutral-position-switch-connector-cannot-be-removed-437.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-diagnostic-tips-for-automatic-transmission-dtc-p0756-second-third-fourth-gear-start-269.html</guid>
										<title>2007 Corvette: Service Bulletin: Diagnostic Tips for Automatic Transmission DTC P0756, Second, Third, Fourth Gear Start</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-diagnostic-tips-for-automatic-transmission-dtc-p0756-second-third-fourth-gear-start-269.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-gm-techlink-hydraulic-clutch-fluid-discoloration-97.html</guid>
										<title>1997 - 2002 Corvette: GM TechLink: Hydraulic Clutch Fluid Discoloration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-gm-techlink-hydraulic-clutch-fluid-discoloration-97.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-automatic-transmission-service-procedure-changes-436.html</guid>
										<title>1997 - 2002 Corvette: Service Bulletin: Automatic Transmission Service Procedure Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-automatic-transmission-service-procedure-changes-436.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-t-56-borg-warner-transmission-repair-manual-1201.html</guid>
										<title>1997 - 2004 Corvette:  T-56 Borg Warner Transmission Repair Manual</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-t-56-borg-warner-transmission-repair-manual-1201.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-gm-techlink-transmission-stuck-in-gear-435.html</guid>
										<title>1997 - 2003 Corvette: GM TechLink: Transmission Stuck in Gear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-gm-techlink-transmission-stuck-in-gear-435.html</link>
