<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-ac-compressor-211.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-base-radio-system-264.html</guid>
										<title>2006 Corvette:  Electrical Schematic:  Base Radio System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-base-radio-system-264.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-347.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin: Intermittent Service Stability Message On DIC With Only DTC C0561 Symptom 71</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-347.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-bulletin-change-in-the-gm-nav-disc-update-program-180.html</guid>
										<title>2008 Corvette: Service Bulletin: Change in the GM Nav Disc Update Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-bulletin-change-in-the-gm-nav-disc-update-program-180.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-actual-outside-temperature-does-not-match-temperature-reading-on-inter-display-normal-operating-characteristic-341.html</guid>
										<title>2005 Corvette: Service Bulletin: Actual Outside Temperature Does Not Match Temperature Reading On Inter Display - Normal Operating Characteristic</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-actual-outside-temperature-does-not-match-temperature-reading-on-inter-display-normal-operating-characteristic-341.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-article-fob-conditions-104.html</guid>
										<title>2005 - 2008 Corvette: GM TechLink Article: Fob Conditions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-article-fob-conditions-104.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-dead-battery-reprogram-rcdlr-233.html</guid>
										<title>2007 Corvette:  Service Bulletin: Dead Battery, Reprogram RCDLR</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-dead-battery-reprogram-rcdlr-233.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-starting-charging-system-267.html</guid>
										<title>2006 Corvette: Electrical Schematic:  Starting - Charging System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-starting-charging-system-267.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-power-distribution-260.html</guid>
										<title>2006 Corvette:  Electrical Schematic:  Power Distribution</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-power-distribution-260.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2019-corvette-gm-techlink-power-folding-top-diagnostic-tips-1410.html</guid>
										<title>2005 - 2019 Corvette: GM TechLink: Power Folding Top Diagnostic Tips</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2019-corvette-gm-techlink-power-folding-top-diagnostic-tips-1410.html</link>
