<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-information-regarding-automatic-transmission-shift-lock-control-function-200.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-malfunction-indicator-lamp-mil-diagnostic-trouble-code-dtc-p0833-cruise-control-inoperative-adjust-clutch-release-switch-344.html</guid>
										<title>2005 Corvette: Service Bulletin: Malfunction Indicator Lamp (MIL), Diagnostic Trouble Code (DTC) P0833, Cruise Control Inoperative (Adjust Clutch Release Switch)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-malfunction-indicator-lamp-mil-diagnostic-trouble-code-dtc-p0833-cruise-control-inoperative-adjust-clutch-release-switch-344.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-customer-satisfaction-program-engine-flywheel-clutch-interference-327.html</guid>
										<title>2006 Corvette: Customer Satisfaction Program: Engine Flywheel/Clutch Interference</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-release-of-dexron-vi-automatic-transmission-fluid-atf-354.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: Release of DEXRON VI Automatic Transmission Fluid (ATF)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-release-of-dexron-vi-automatic-transmission-fluid-atf-354.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-diagnostic-tips-for-automatic-transmission-dtc-p0756-second-third-fourth-gear-start-269.html</guid>
										<title>2007 Corvette: Service Bulletin: Diagnostic Tips for Automatic Transmission DTC P0756, Second, Third, Fourth Gear Start</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-diagnostic-tips-for-automatic-transmission-dtc-p0756-second-third-fourth-gear-start-269.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-4l60-e-4l65-e-automatic-transmission-fluid-leak-from-oil-pump-or-bell-housing-area-276.html</guid>
										<title>2006 Corvette: Service Bulletin:  4L60-E, 4L65-E Automatic Transmission fluid Leak from Oil Pump or Bell Housing Area</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-4l60-e-4l65-e-automatic-transmission-fluid-leak-from-oil-pump-or-bell-housing-area-276.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-information-on-driveline-clunk-noise-when-shifting-between-park-and-drive-park-and-reverse-or-drive-and-reverse-214.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin: Information on Driveline Clunk Noise When Shifting Between PARK and DRIVE, PARK and REVERSE or DRIVE and REVERSE</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-information-on-driveline-clunk-noise-when-shifting-between-park-and-drive-park-and-reverse-or-drive-and-reverse-214.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-6l80-automatic-transmission-delayed-engagement-from-park-to-drive-or-park-to-reverse-reprogram-transmission-control-module-tcm-275.html</guid>
										<title>2006 Corvette: Service Bulletin: 6L80 Automatic Transmission Delayed Engagement From PARK to DRIVE or PARK to REVERSE (Reprogram Transmission Control Module (TCM))</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-6l80-automatic-transmission-delayed-engagement-from-park-to-drive-or-park-to-reverse-reprogram-transmission-control-module-tcm-275.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2006-corvette-service-bulletin-diagnostic-information-on-diagnostic-trouble-code-dtc-p0894-and-p1870-215.html</guid>
										<title>2000 - 2006 Corvette: Service Bulletin: Diagnostic Information on Diagnostic Trouble Code (DTC) P0894 and P1870</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2006-corvette-service-bulletin-diagnostic-information-on-diagnostic-trouble-code-dtc-p0894-and-p1870-215.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-information-hydra-matic-6l80-six-speed-automatic-car-truck-transmission-137.html</guid>
										<title>2008 Corvette: Service Information: Hydra-Matic 6L80 Six-Speed Automatic Car &amp; Truck Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-information-hydra-matic-6l80-six-speed-automatic-car-truck-transmission-137.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-diagnosis-of-cracked-or-broken-transmission-case-271.html</guid>
										<title>2006 Corvette: Service Bulletin:  Diagnosis of Cracked or Broken Transmission Case</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-diagnosis-of-cracked-or-broken-transmission-case-271.html</link>
