<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-language-change-for-onstar-system-u-s-only-197.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-removal-of-radio-fuse-before-attempting-to-program-reprogram-modules-using-service-program-system-sps-343.html</guid>
										<title>2005 Corvette: Service Bulletin: Removal of Radio Fuse Before Attempting to Program/Reprogram Modules Using Service Program System (SPS)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-removal-of-radio-fuse-before-attempting-to-program-reprogram-modules-using-service-program-system-sps-343.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2010-corvette-service-bulletin-pic5346a-normal-characteristic-unable-to-answer-a-second-incoming-bluetooth-call-or-continues-to-ring-after-answering-a-second-incoming-call-1329.html</guid>
										<title>2009 - 2010 Corvette: Service Bulletin: #PIC5346A: Normal Characteristic - Unable To Answer a Second Incoming Bluetooth call or Continues To Ring After Answering a Second Incoming Call</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-347.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin: Intermittent Service Stability Message On DIC With Only DTC C0561 Symptom 71</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-347.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-sir-lamp-on-336.html</guid>
										<title>2005 Corvette: GM TechLink: SIR Lamp On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-sir-lamp-on-336.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-service-bulletin-special-coverage-adjustment-airbag-light-on-1264.html</guid>
										<title>2005 - 2013 Corvette: Service Bulletin: Special Coverage Adjustment - Airbag Light On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-service-bulletin-special-coverage-adjustment-airbag-light-on-1264.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2016-corvette-15521-customer-advisory-letter-side-door-release-operation-phase-2-mailing-1268.html</guid>
										<title>2005 - 2016 Corvette: 15521 - Customer Advisory Letter - Side Door Release Operation - Phase 2 Mailing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2016-corvette-15521-customer-advisory-letter-side-door-release-operation-phase-2-mailing-1268.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-door-locks-213.html</guid>
										<title>2006 Corvette: Electrical Schematic: Door Locks</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-door-locks-213.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-gm-techlink-electronic-brake-control-module-communication-67.html</guid>
										<title>2009 - 2011 Corvette: GM TechLink:  Electronic Brake Control Module Communication</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-gm-techlink-electronic-brake-control-module-communication-67.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2008-corvette-service-campaign-unwanted-repeat-calls-to-onstar-13.html</guid>
										<title>2004 - 2008 Corvette: Service Campaign: Unwanted Repeat Calls to OnStar</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2008-corvette-service-campaign-unwanted-repeat-calls-to-onstar-13.html</link>
