<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-misfire-dtcs-p0300-p1380-p1381-and-catalytic-converter-damage-due-to-installation-of-alarm-systems-194.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-malfunction-indicator-lamp-mil-diagnostic-trouble-code-dtc-p0833-cruise-control-inoperative-adjust-clutch-release-switch-344.html</guid>
										<title>2005 Corvette: Service Bulletin: Malfunction Indicator Lamp (MIL), Diagnostic Trouble Code (DTC) P0833, Cruise Control Inoperative (Adjust Clutch Release Switch)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-malfunction-indicator-lamp-mil-diagnostic-trouble-code-dtc-p0833-cruise-control-inoperative-adjust-clutch-release-switch-344.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-347.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin: Intermittent Service Stability Message On DIC With Only DTC C0561 Symptom 71</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-347.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2012-corvette-service-bulletin-pic5485a-noticeable-difference-in-audio-volume-level-when-selecting-favorites-or-switching-between-the-am-fm-bands-cd-and-or-xm-oct-24-2011-1339.html</guid>
										<title>2005 - 2012 Corvette: Service Bulletin: #PIC5485A: Noticeable Difference In Audio Volume Level When Selecting Favorites Or Switching Between The AM/FM Bands CD And/Or XM - (Oct 24, 2011)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2012-corvette-service-bulletin-pic5485a-noticeable-difference-in-audio-volume-level-when-selecting-favorites-or-switching-between-the-am-fm-bands-cd-and-or-xm-oct-24-2011-1339.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2011-corvette-gm-techlink-head-up-display-conditions-69.html</guid>
										<title>1999 - 2011 Corvette:  GM TechLink: Head-Up Display Conditions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2011-corvette-gm-techlink-head-up-display-conditions-69.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2012-corvette-gm-techlink-article-noticeable-difference-in-audio-volume-level-38.html</guid>
										<title>2005 - 2012 Corvette: GM TechLink Article: Noticeable Difference in Audio Volume Level</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2012-corvette-gm-techlink-article-noticeable-difference-in-audio-volume-level-38.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-2013-corvette-service-bulletin-ses-lamp-p0521-setting-after-an-oil-change-and-or-low-oil-pressure-indicated-on-the-instrument-panel-1279.html</guid>
										<title>2007 - 2013 Corvette:  Service Bulletin: SES Lamp P0521 Setting After An Oil Change And Or Low Oil Pressure Indicated On The Instrument Panel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-2013-corvette-service-bulletin-ses-lamp-p0521-setting-after-an-oil-change-and-or-low-oil-pressure-indicated-on-the-instrument-panel-1279.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-article-door-handle-release-button-101.html</guid>
										<title>2005 - 2008 Corvette: GM TechLink Article: Door Handle Release Button</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-article-door-handle-release-button-101.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-removal-of-radio-fuse-before-attempting-to-program-reprogram-modules-using-service-program-system-sps-343.html</guid>
										<title>2005 Corvette: Service Bulletin: Removal of Radio Fuse Before Attempting to Program/Reprogram Modules Using Service Program System (SPS)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-removal-of-radio-fuse-before-attempting-to-program-reprogram-modules-using-service-program-system-sps-343.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-2013-corvette-service-bulletin-ses-lamp-p0521-setting-after-an-oil-change-and-or-low-oil-pressure-indicated-on-the-instrument-panel-1273.html</guid>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-2013-corvette-service-bulletin-ses-lamp-p0521-setting-after-an-oil-change-and-or-low-oil-pressure-indicated-on-the-instrument-panel-1273.html</link>
