<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-power-windows-189.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</guid>
										<title>1973 Corvette:  Electrical Schematic: Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-ecm-codes-693.html</guid>
										<title>1981 Corvette: ECM Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-ecm-codes-693.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-heat-damage-to-engine-wiring-harness-943.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Heat Damage to Engine Wiring Harness</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-heat-damage-to-engine-wiring-harness-943.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-1984-corvette-service-bulletin-power-antenna-rod-and-cable-service-package-1015.html</guid>
										<title>1979 - 1984 Corvette:  Service Bulletin:  Power Antenna Rod and Cable Service Package</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-1984-corvette-service-bulletin-power-antenna-rod-and-cable-service-package-1015.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-headlamp-opening-interference-696.html</guid>
										<title>1969 Corvette: Service Bulletin: Headlamp Opening Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-headlamp-opening-interference-696.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-checking-connector-terminal-contact-metri-pack-691.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Checking Connector Terminal Contact - Metri-Pack</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-checking-connector-terminal-contact-metri-pack-691.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-discharged-battery-906.html</guid>
										<title>1968 Corvette:  Engineering Service Letter:  Discharged Battery</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-discharged-battery-906.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-passenger-car-product-bulletin-new-corvette-anti-theft-warning-system-1235.html</guid>
										<title>1968 Corvette:  Passenger Car Product Bulletin:  New Corvette Anti-Theft Warning System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-passenger-car-product-bulletin-new-corvette-anti-theft-warning-system-1235.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-automatic-transmission-kickdown-switch-191.html</guid>
										<title>1973 Corvette:  Electrical Schematic:  Automatic Transmission Kickdown Switch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-automatic-transmission-kickdown-switch-191.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1977-corvette-service-bulletin-use-of-1976-model-ignition-key-sets-in-1977-chevrolet-passenger-vehicles-1251.html</guid>
										<title>1976 - 1977 Corvette:  Service Bulletin:  Use of 1976 Model Ignition Key Sets in 1977 Chevrolet Passenger Vehicles</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1977-corvette-service-bulletin-use-of-1976-model-ignition-key-sets-in-1977-chevrolet-passenger-vehicles-1251.html</link>
